This is the form factor I am most interested in (rear power connection for ceiling mounting). Very interested to know if it has the ‘non-spammy’ firmware onboard. Have you been able to confirm? If it does I will go ahead and order one.
Ok so this one looks like a 5.8g sensor ( _TZE200_2aaelwxk). I was really hoping for the 24g on this one because I really like the form factor on it. They did a great job on the ball pivot and its very small. I also thought it worked pretty well.
When you pair all of the new toys to HE, please add the Device Details Data sections (as text) to your previous posts, so that we can identify the different models easier.
Aliexpress is based in China but is a legit site that ships worldwide. Like any online marketplace, caveat emptor, but there’s no inherent security risk to browsing their website.
Just for clarification I believe this member was actually referring to not being able to access the manual for the device that I linked above rather than Aliexpress. But everyone should be careful with Aliexpress. I haven't had serious issues, but it's wise to approach it with caution.
@kkossev I've updated the above posts for the 2 mains units. Neither of them took an update when connected to the Tuya hub. They don't appear to have the same level of detail available as some other devices. Like no breathe setting. They do have the relay on them.
This looks like the one I posted above just a few posts up. Mine was a 5.8g sensor inside. I hope yours is a 24g. They are a bit of a pain to open. I squeezed the ends to get it to open the gap on the sides. The back cap is held in on the ends, but if you get a spudger in the side you can work to the end. The ball is friction fit on a post on the back so don't worry if you pull it off.
