The Hubitat C-8 just hit fccid.io
https://fccid.io/2AHYK-2212C8
From my quick read through ....
  1. Same size as C-7/C-5
  2. Built-in WiFi
  3. External antenna
  4. The power requirement (1.1A @ 5VDC) suggests it will not use a microUSB connector
I don't understand much of what I am reading there but much of it seems sketchy.
Oh wow, I stand corrected! I clicked on the manufacturer and the previous generations are listed with correct dates specs.
CES announcement?!
Nice find!
Interesting specs. Built-in Wifi and the antennas don't surprise me. Nice upgrade if so.
Hopefully USB-C or barrel connector this time instead of that terrible micro-USB.
Edited my original post.
Probably - makes sense why most of the team is at CES!
It does! I don't recall them having this kind of presence before.
There's no information I could find easily about the Z-Wave and Zigbee SoCs used. My guess is 800-series for Z-Wave, because of its availability and the name "C-8".
This is a very exciting idea. I'll definitely be watching for announcements!
However if there is a FCC filing it's gotta be happening. Question is when? I don't have a good concept of the typical time line between filing and release of things.
Going by the C-5 and C-7 filing v/s release date, I would say 3-6 months.
Ah that makes sense. I assume they need the ID to do testing etc. That is something they have always been great at. Excellent job making sure things are right.
The power spec exceeds microUSB. I'm okay with USB-C, but hoping it's barrel.
I'm oddly fired up about this. I almost want to tag someone in support.
Seriously why am I almost giddy about this?
:rofl::rofl::rofl:
Yea - you should be totally giddy.
Who has 2 thumbs and is ready to upgrade even if there is no pragmatic reason to do so???
:+1::grinning::+1: This guy!
I’d get one as soon as it becomes available. Oh what fun I’ll have attempting to migrate 47 Z wave 500 series devices with Z stick to avoid S0….I can’t wait
I've been testing another 800-series z-wave controller with a different stack (ZWaveJS). Haven't run into this issue. So I cautiously optimistic that it'll be okay with Hubitat's new hub as well.
I know it’s down to silabs rather than Hubitat but It would be great if that issue is finally resolved
Just reading one of the zigbee test documents.
Mentions external antenna.
I think it is a single antenna for z-wave and zigbee.
As far as I know, the 800-series Z-Wave chip uses the same SDK as the 700-series SDK (which, ignoring this particular concern, is probably good news given that they hopefully have their stuff figured out now, unlike the early days of 700 :rofl: ). I would expect Hubitat to continue using that, though I suppose we don't really know.
I don't believe Z-Wave JS has this concern regardless of hardware because they are not using the SDK but rather implementing all this functionality on their own. As a result, they are not bound by whatever constraints the SDK imposes — no option to ignore S0 on non-S2 devices when the device requests secure inclusion being one of them.
