Terncy Smart Dial - TERNCY-SD01 - anyone?
Hi,
I'm looking for a Zigbee dial to control some dimmer modules.
The only one I found so far is this one.
R$ 151,46 16%OFF | Terncy Smart Dial TERNCY-SD01 Smart scene master support Apple HomeKit (need to work with gateway )
Does anyone know if it works with HE ?
thanks
Hi,
I'm testing this smart dial but it's not pairing with Hubitat.
What zigbee channel is your Hubitat configured to use?
It's using zigbee channel 20.
I changed the channel and now it's paired.
But I didn't find any drivers that work with it. It's configured with the 'Zigbee - Generic Device Toolbox' from Oh-la-labs and when some actions are done the log shows:
1 - Push:
Unhandled Event IGNORE THIS - description:catchall: 0104 FCCC 01 6E 0040 00 9A82 01 01 1228 00 01 6F01 | msgMap:[raw:catchall: 0104 FCCC 01 6E 0040 00 9A82 01 01 1228 00 01 6F01, profileId:0104, clusterId:FCCC, clusterInt:64716, sourceEndpoint:01, destinationEndpoint:6E, options:0040, messageType:00, dni:9A82, isClusterSpecific:true, isManufacturerSpecific:true, manufacturerId:1228, command:00, direction:01, data:[6F, 01]]
2 - Hold:
Unhandled Event IGNORE THIS - description:catchall: 0104 FCCC 01 6E 0040 00 9A82 01 01 1228 14 01 01 | msgMap:[raw:catchall: 0104 FCCC 01 6E 0040 00 9A82 01 01 1228 14 01 01, profileId:0104, clusterId:FCCC, clusterInt:64716, sourceEndpoint:01, destinationEndpoint:6E, options:0040, messageType:00, dni:9A82, isClusterSpecific:true, isManufacturerSpecific:true, manufacturerId:1228, command:14, direction:01, data:[01]]
3 - Double Tap:
Unhandled Event IGNORE THIS - description:catchall: 0104 FCCC 01 6E 0040 00 9A82 01 01 1228 00 01 3D02 | msgMap:[raw:catchall: 0104 FCCC 01 6E 0040 00 9A82 01 01 1228 00 01 3D02, profileId:0104, clusterId:FCCC, clusterInt:64716, sourceEndpoint:01, destinationEndpoint:6E, options:0040, messageType:00, dni:9A82, isClusterSpecific:true, isManufacturerSpecific:true, manufacturerId:1228, command:00, direction:01, data:[3D, 02]]
4 - Rotate to the Right:
Unhandled Event IGNORE THIS - description:read attr - raw: 9A8201FCCC141B00290C001A00216001, dni: 9A82, endpoint: 01, cluster: FCCC, size: 14, attrId: 001B, encoding: 29, command: 0A, value: 0C001A00216001 | msgMap:[raw:9A8201FCCC141B00290C001A00216001, dni:9A82, endpoint:01, cluster:FCCC, size:14, attrId:001B, encoding:29, command:0A, value:000C, clusterInt:64716, attrInt:27, additionalAttrs:[[value:0160, encoding:21, attrId:001A, consumedBytes:5, attrInt:26]], valueParsed:12]
5 - Rotate to the Left:
Unhandled Event IGNORE THIS - description:read attr - raw: 9A8201FCCC141B0029F4FF1A00216001, dni: 9A82, endpoint: 01, cluster: FCCC, size: 14, attrId: 001B, encoding: 29, command: 0A, value: F4FF1A00216001 | msgMap:[raw:9A8201FCCC141B0029F4FF1A00216001, dni:9A82, endpoint:01, cluster:FCCC, size:14, attrId:001B, encoding:29, command:0A, value:FFF4, clusterInt:64716, attrInt:27, additionalAttrs:[[value:0160, encoding:21, attrId:001A, consumedBytes:5, attrInt:26]], valueParsed:-12]
Can someone help us with this device ?
Thanks.
Replying to an old comment so that others who come looking find the correct answer.
Yes, this device works. You may need to change the Zigbee channel from the default of 20 to 15. I don't know why this works, but it worked for me.
You may also be interested in the driver I wrote: [BETA] xiaoyan - terncy-sd01 driver
