SwitchBot gets an open API!
Thank you. A simple fix that worked completely.
Sorry if this was already mentioned in the thread (I did a search but couldn't find the answer) - can I use the blind tilt directly with a hubitat c-7 via Google home or do I need the switchbot hub?
I have never used Google Home for much of anything but I just added it and tried it; works fine.
I have a C8 though.
I have a Meter Pro unit that I picked up on a black friday sale. Would this same trick work for that? It doesn't create a child device for it. I also tried bringing it in via Matter with my Hub Mini but that doesn't work either just gives a temperature reading of 32 which is neither accurate for C or F lol.
Possibly could work, you'd have to figure out what deviceType it is, and add it as Meter.
(like above - "MeterPlus", "WoIOSensor")
Maybe you'll get temp/humidity if the format is the same, but not any of the newer features
I’ll see if I can figure it out. The only extra feature it has over their regular Meter units is it can display a secondary temperature source on its display so I have my outdoor sensor display as the secondary. I only care about the internal sensor.
Hiiii
I'm in a similar problem
I have this adding pushing button Create Child Devices:
dev:1402025-01-14 21:28:42.302debugdevice = [deviceType:Meter, hubDeviceId:, deviceId:F4203C9CE938, deviceName:Meter, enableCloudService:false]
dev:1402025-01-14 21:28:42.302debugcreateChildDevice() failed: deviceType not supported
dev:1402025-01-14 21:28:42.301debugcreateChildDevice: deviceType not supported
dev:1402025-01-14 21:28:42.299debugdevice = [deviceType:Hub Mini2, hubDeviceId:, deviceId:C1211CD634F7, deviceName:Hub Mini F7, enableCloudService:true]
i see the Meter from the app log:
app:552025-01-14 21:08:43.777debugprocessed event: [battery:100, deviceId:F4203C9CE938, deviceType:Meter, humidity:40, scale:CELSIUS, temperature:18, timeOfSample:1736885322066]
app:552025-01-14 21:08:43.776debugincoming event: [context:[battery:100, deviceMac:F4203C9CE938, deviceType:WoMeter, humidity:40, scale:CELSIUS, temperature:18, timeOfSample:1736885322066], eventType:changeReport, eventVersion:1]
app:552025-01-14 20:49:22.148debugprocessed event: [battery:100, deviceId:F4203C9CE938, deviceType:Meter, humidity:40, scale:CELSIUS, temperature:18.1, timeOfSample:1736884160427]
app:552025-01-14 20:49:22.147debugincoming event: [context:[battery:100, deviceMac:F4203C9CE938, deviceType:WoMeter, humidity:40, scale:CELSIUS, temperature:18.1, timeOfSample:1736884160427], eventType:changeReport, eventVersion:1]
where is my error?
@tomw please help
@tomw Hey! First off, thank you for the custom driver. I love it for my multiple SwitchBot devices! I use a SwitchBot mini hub to connect my devices to my Hubitat hub but I've run into a problem. The Hubitat device integration doesn't seem to recognize the new Smart Meter Pro CO2. Is this just something that can be added to the driver or is there something I'm doing wrong? Here's a screenshot of the error I'm getting in the logs.
Sorry for the late reply. I will analyze the code as soon as possible.
i cant recreate this situation
Is the new Meter Pro with CO2 supported? What I can try on my end?
Hi!
I just installed a SwitchBot Garage Door Opener, looking to see if it can get support in the app as well.
dev:1312025-08-01 10:27:27.816 AMdebugcreateChildDevice() failed: deviceType not supported
dev:1312025-08-01 10:27:27.814 AMdebugcreateChildDevice: deviceType not supported
dev:1312025-08-01 10:27:27.811 AMdebugdevice = [deviceType:Garage Door Opener, hubDeviceId:, deviceId:94A990A68D62, deviceName:Big Garage Door, enableCloudService:true]
Hi there! Love this integration. I’ve just added a few new remotes to my hub mini and a scene, but I can’t seem to get the parent device to pick them up — no amount of hitting the Refresh or Create Child Devices buttons seems to do anything. Is there a step I’m missing?
@tomw Thanks for creating this API. I have been using it for a few years now and love it! I recently upgraded from a Switchbot Lock to a Switchbot Lock Ultra (love the sleeker look of the Ultra). I am not able to get Hubitat to recognize the new lock eventhough it shows up in the devices variable. Any chance you could help me get this set-up and working like the original Switchbot Lock.
Did you ever get your ultra working with Hubitat? I suspect it’s not compatible with @tomw otherwise amazing integration.
I just upgraded to the Ultra as well. Wondering how anyone has gotten this working... If they have.
Well it did work. It took about a half hour to show up. I seem to remember that being the case before when I added the old lock.
Interesting because I still can't get it to work. I get these error messages, which suggest to me that "Smart Lock Ultra" is not a supported device. Is it still working for you and is your device type as "Smart Lock Ultra". @tomw, any suggestions?
**dev:1955**2026-10-13 12:49:56.184 pm debug createChildDevice() failed: deviceType not supported
**dev:1955**2026-10-13 12:49:56.183 pm debug createChildDevice: deviceType not supported
**dev:1955**2026-10-13 12:49:56.179 pm debug device = [deviceType:Smart Lock Ultra, hubDeviceId:E526740DA82D, deviceId:B0E9FE82882A, deviceName:Front Door Lock, enableCloudService:true, group:false, master:true, lockDevicesIds:[]
Yep. Works for me. I’ll share the info
Part 1
Part 2
