Hi @tony4mikki , I saw your post here: SwitchBotAPI Driver for SwitchBot Bot - #49 by tony4mikki
If you installed my drivers using HPM, make sure you installed the optional drivers for each device type that you plan to use.
If you have a SwitchBot System virtual device configured, you then have to click the createChildDevices button. That should create a SwitchBot Meter child device for your HT meter.
I just tested my meter and it is still returning readings as expected.
