Hey @kraegd, I saw your post here: SwitchBotAPI Driver for SwitchBot Bot
I'm not sure what may be wrong, but I'll bet we can figure it out. I still don't have a curtain device, but some other users here have gotten it to work.
To start, can you tell me what version of the driver is quoted under this line in the driver source for the curtain driver? Change history:
Some of the earliest versions tried to check if the curtain was properly calibrated, which the API didn't actually reliably report. It made my driver non-functional in a lot of cases. I removed that check and also made a number of other corrections on the attribute handling for windowShade and position.
So, since all of that is not working, I'm wondering if you have an older version that had those bugs.
