SwitchBot gets an open API!
Hey @kraegd, I saw your post here: SwitchBotAPI Driver for SwitchBot Bot
I'm not sure what may be wrong, but I'll bet we can figure it out. I still don't have a curtain device, but some other users here have gotten it to work.
To start, can you tell me what version of the driver is quoted under this line in the driver source for the curtain driver? Change history:
Some of the earliest versions tried to check if the curtain was properly calibrated, which the API didn't actually reliably report. It made my driver non-functional in a lot of cases. I removed that check and also made a number of other corrections on the attribute handling for windowShade and position.
So, since all of that is not working, I'm wondering if you have an older version that had those bugs.
Hi Tom,
I was running the latest version from your GitHub.
I decided to delete all my child devices and recreate them, after that things started to work...no clue what had gone on!
Thanks for the response, if you need anything testing add my to the volunteers. I'm hoping to order a few more of these as they seem to be an ok solution ... Although not perfect.
Kraeg
use HPM to ensure you stay up to date on everything
I've just installed a SwitchBot Curtain and am seeing something odd. In the device page all of the buttons work. The curtain will open and close with those buttons, as well as the on/off buttons. The curtain will even go to the correct position if I use that to open the part way, see image.
What the device is not doing is updating the Current States when the curtain is fully closed. On the device page, if I hit the Close or Off button the curtain will move, but the state will not update. If I set the position to 100 the curtain will fully close, but not update the states and still show on/open.
25% Position:
100% Position still shows on/open:
I installed using HPM. Oh, and this is a grouped curtain device.
I think my logic is flipped.
Is 100% closed? I figured 100% was opened, like a dimmer being set to 100% brightness.
@dadarkgtprince, @rudyscoggins, does the behavior that @jason described match what you saw with your curtains?
This is the logic right now:
else if(respData.body?.slidePosition)
            switch(respData.body.slidePosition.toInteger())
                case 95..100:
                    windowShade = "open"
                    switchState = "on"
                    break
                case 0..5:
                    windowShade = "closed"
                    switchState = "off"
                    break
                default:
                    windowShade = "partially open"
                    switchState = "off"
Here is what I'm showing in the SwitchBot app. I think the logic is opposite of what you have. With the sliders in the app at 25% you get 25% of coverage. At 100% you get full coverage and the app shows fully closed.
OK, should be an easy fix. Please try updating to 0.9.8 via HPM and see if you get better results.
The logic for percentage and open/close, on/off is good. It does look like the API is slow to update itself. I'll use Hubitat to issue a Open/On command and the curtain will move, but the debug logs show that the slidePosition isn't changed.
Here is what I'm seeing in the logs:
dev:25682021-03-05 05:05:58.946 pm debugresp.data = [statusCode:100, body:[deviceId:redacted, deviceType:Curtain, hubDeviceId:redacted, slidePosition:100], message:success]
dev:25682021-03-05 05:05:58.329 pm debughttpGetExec([uri:https://api.switch-bot.com/v1.0/devices/redacted/status, headers:[Authorization:redacted, Content-Type:application/json; charset=utf8]])
dev:25682021-03-05 05:05:56.255 pm debugresp.data = [statusCode:100, body:[:], message:success]
dev:25682021-03-05 05:05:55.145 pm debughttpPostExec([uri:https://api.switch-bot.com/v1.0/devices/redacted/commands, headers:[Authorization:redacted, Content-Type:application/json; charset=utf8], body:{"command": "turnOn", "parameter": "default","commandType": "command"}])
Then the SwitchBot system device did a refresh and the slidePosition is now 0:
dev:25682021-03-05 05:07:08.265 pm debugresp.data = [statusCode:100, body:[deviceId:redacted, deviceType:Curtain, hubDeviceId:redacted, calibrate:true, group:false, moving:false, slidePosition:0], message:success]
dev:25682021-03-05 05:07:07.691 pm debughttpGetExec([uri:https://api.switch-bot.com/v1.0/devices/redacted/status, headers:[Authorization:redacted, Content-Type:application/json; charset=utf8]])
However, the Curtain device page still shows the Current States as 100/off/closed
You're right- the logic for attribute updates still seems kind of wrong. Your debug prints help. I'll take another pass through the logic and hit you up for further testing.
I think I found the error in my code. I just made a fix but did not change the version, so just use the Repair option in HPM to get the change.
I did the Repair to grab the new code. When I use Hubitat to open or close the signal gets sent and the curtains move, but the API fails to update the status for a beat. I can hit Refresh of the child and/or the parent device and it will not have the new status for at least 30 seconds if not a minute. That is not anything you can do I'm sure. When I hit refresh with the logging open the response from switchbot will be wrong for a beat or two.
That's unfortunate, but it does seem like their API is pretty laggy. If it eventually catches up then that may be the best we can do.
One tweak I could add is to lengthen the time that the driver waits before refreshing after a command to move the device is sent. Right now it's really short- 2 seconds. If it was consistently 30 seconds (or whatever) I could adjust to make it as responsive as possible.
How consistent is the delay if you manually refresh it until it updates
I'll mess around with the curtains tomorrow and make some notes on how long it takes the API to respond.
Attempt Number One; Curtain started in the open position, status in Hubitat was 0/On/Open. I hit the Close button at 08:23:30.724 am. I then hit refresh repeatedly starting when the curtain was fully closed and not moving. The first response with slidePosition:99 (not 100 for some reason) was at 08:25:17.104 am. This was 1m 47s.
Attempt Number Two; Curtain starting the closed position, status in Hubitat was 99/Off/Closed. I hit the open button at 08:42:42.897 am. The state change to 0/On/Open was refreshed at 08:43:20.411 am. This run was much better at 38 Seconds.
I ran another cycle and got these times: Open to Close: 2m 4s. Closed to Open: 41s.
It takes a much shorter time for the API to update with an open command than a close command. My curtain takes about 15 seconds to move from full stop to full stop.
I have also noticed that if the curtain is in the 100/Off/Closed state and you press the Close button the state will change immediately to 0/On/Open. It will stay in that state until the API is updated and refreshed in Hubitat.
unfortunately when i was testing, i wasn't too concerned with the attributes as much as i was about the functionality. i always figured i could just look at my blinds (open floor plan) and see if they're open/closed. i wasn't too interested in the partial open/close, so i didn't go too much into that.
i just got a few of the Bots if you need anymore testing done with them
I am a noob using hubitat, can someone show a step by step on how to execute a switchbot ir command,for example volumeAdd (I already have my curtains working)
Hello @mdjuarez. Welcome!
I have some usage instructions here: SwitchBot gets an open API! - #17 by tomw
If you have the IR device details added in the SwitchBot app, you can use createChildDevices in my driver to create them for access by Hubitat. Then you can use them as described on that page.
Are you able to control your devices from within the SwitchBot app? Do you see the child devices for IR in Hubitat?
Hello @tomw thank you for your reply. Yes I have the devices in the switchbot app and I can see them in hubitat.
I even managed to open the curtains with a smart button in hubitat. But I can not figured out how to use the ir devices with commands
Check out this readme from my driver, specifically the section called 'Usage instructions:' hubitat_switchbot/README.md at main · tomwpublic/hubitat_switchbot · GitHub
It links to the SwitchBotAPI reference, where you find a list of commands (like volumeAdd which you mentioned) and their parameters. So, you just have to specify the Command and command parameter values from their table. If a command parameter is listed as default (as most are), you can just leave it blank in the Hubitat page.
