I have a Leviton Dimmer that will not update status if it’s on or off. The unit works with manual control within the app
This is a new issue after a recent update.
I have a rule that triggers based on the light Turning in and it’s stopped recently.
Switch is currently off.
Could you confirm that the device is Z-Wave plus? If not, is it setup in the Z-Wave device poller app?
Assuming it is either a plus device or setup in the poller app, it might be that the hub and the device are not properly communicating. This could be due to a Z-Wave mesh issue. Posting the Z-Wave mesh details will allow community members to help identify potential issues.
Finally, to confirm the issue was not introduced with the last platform version, it is possible to go back to the previous one by going to http://Hubitat.local:8081
There could still be Z-Wave issues, especially if some devices didn’t pair correctly (called “ghost”). Sharing a (or multiple) screenshot(s) of your Z-Wave details will allow community members to identify potential mesh issues, including the presence of Ghost devices.
These can cause havoc on the mesh (I experienced that a while back and got some great help from the community!)
Also, if your Z-Wave firmware is not updated to the last version, it should be as there are some fixes that were made available from Silabs that are present in the latest versions. You can look for a “Firmware update” button on the Z-Wave Details screen.
Updating the hub's z-wave radio's firmware, which is the button indicated in @Sebastien's response to your post. You need to do this for a stable z-wave network because the initial firmware provided for 700-series controllers had many defects in it. Updating this firmware will not make you have to exclude/include any devices.
Updating the firmware of individual z-wave devices, which is done in a different app. This may require you to exclude/include the device whose firmware was updated. Updating the firmware of individual z-wave devices is entirely at your discretion - and most often not necessary.
I will check that and update. I have several other issues now. Govee and Hubitat apps not working, local app connection. Etc. I’m digging through all of these issues at this moment
The Z-Wave Radio’s firmware update should indeed be relatively quick. Though I think it can take in the 15 minute range sometimes… It’s been a while since I updated…
This si what i get when i try the ZWave firmware update. My hub has continued to act up on certain Zwave devices... Normally a reboot or two solves it but I am not use to having to reboot alot like
That’s not normal - I wonder if these issues might not be related… I’ll second @aaiyar’s recommendation to post your entire Z-Wave settings page.
