Nah need a usb stick to use in a pc.
You can pick one up on mouser for cheap. They come in handy for firmware updates and killing stubborn ghosts as well as checking mesh health.
https://www.mouser.com/ProductDetail/Silicon-Labs/SLUSB001A?qs=u16ybLDytRbJsMfgk3EnSA%3D%3D
There is no beta release at the time of this reply, but it is imminent. I'll add your hub to the list once it's out.
Ordered one.
I just had a thing happen with Sunset in C7/2.2.3.145.
I have a switch to turn on at Sunset -60 minutes and off at 11:30 PM.
It had been working for a while.
Today was the first day of Standard Time, (Spring Ahead/Fall Back).
It turned on almost exactly an hour too early (according to Accuweather for my zip code).
I turned it off manually, and it came on at the correct time.
Weird.
Daylight savings time maybe didn't schedule correctly? It will probably work right tomorrow though.
Don't mean to brag, however.... mine worked as designed
Ok, I have the stick now. I ended up getting one from Zooz.
Silicon Lab site is not allowing new user registration for some reason. Tried different machines browsers (Safari, Chrome), same issue. I will try again tomorrow with a hope that their backend is fixed.
Btw, is PC Controller app Windows only?
Yes. PC Controller is Windows only. The rest of SimplicityStudio doesnβt have that limitation.
But you can run it in a virtual box.
If it's not against their EULA, can someone share the installed/executable for PC controller? Their site is still having issues and not allowing new account registration. To open a support case or to post in their community, all requires an account. Same issue as earlier.
I am still not able to create an account at sillabs and can't contact their support w/o the account either. Can you please share the issue on their forum on my behalf. Here is the video walkthru of the issue.
Sunset bug rears its head again (in 2.2.5.127).
Today is end of daylight saving here in NSW (Australia) and all my simple automations fired 1 hour early.
Which is what I have - I assume this hasn't been fixed yet?
Current firmware is well past that (2.2.6.137).
So has the bug acknowledged by @gopher.ny been fixed between then and 2.2.6? I didn't see anything in any of the release notes unless I missed it.
EDIT : is this it? " * Simple Automation Rule-1.1: Fix before sunrise/sunset."
All I know is that it works correctly for us each morning. C-7, 2.2.6.137.
Normally works fine very day for me too in my (older) version. It's just today that is our transition from DST.
It may be an issue for U.K. Australia that is not present in U.S.
I'm in Australia
