Hi, I'm new here and I need help with the driver for this device.
Thank you in advance for any help
[4 Groups Touch Panel Dual Color Z Wave Secondary Controller SR-ZV9001T4-CCT-EU]
Welcome to the Hubitat forums!
I cannot tell if you need a driver, or a driver is not working correctly?
Hi neonturbo. First of all, I apologize for the errors in the text, but I don't speak English very well.
Normally this touch panel is designed for direct assignment of z-wave devices (according to the documentation).
But I need to control the zigbee lights (4 Groups)
this panel is very similar to RGBGENIE in topics below, but it doesn't work with this driver
I will see if our Zwave expert has an idea if these can be made to work with Hubitat.
@bcopeland can you take a look at this device listed above?
I have this deviceโฆ There are some difficulties with how it wants to send packets back to the hub with the 700 series SDK.. I may have a solution, but itโs pretty complicated and incompatible with pre C7..
it partially works with the driver RGBgenie Controller ZW-3003. I can turn on/off, set the level, scene buttons S1-S4. (1 group/zone)
color temperature does not work
I found also another manual... there are many differences
http://valotehdas.fi/wp-content/uploads/2017/11/sr-zv9002t4-cct-eu-user-manual-1.pdf
