perfect, and when using this driver, what button events and numbers get generated?
Also the fingerprint would be helpfull, you can fetch this by replacing the current driver with the driver named 'Device', open live logging, click the getInfo command, then immediately push one of the buttons on the controller to wake it up.
Let me see if I can get a sample sent over on our next shipment. We don't carry this item in the US as it is designed for an EU style electrical box. But an 8 button controller does sound enticing.
I have the same button controller. Unfortunately, using the button controller-app, I have the same issue as you do.
A work-around I have used is using the "Generic Z-Wave button controller" as driver, and then creating a rule for each button push (that will result in 8 rules per device). It does of course not scale very well, but it will get the work done until someone capable has the time to create a driver.
we'll have a driver for this device in platform 2.1.9, please note that the device will need to be removed, factory reset then rejoined to work properly after you install the 2.1.9 update (which should release within a week or two tops...)
