These Visonic MP-840s are not only pet immune but have a sensitivity jumper that allows you to up the motion count before it will register as a triggering. That jumper often does the trick if you really have a problem with falsing.
Visonic has been in the forefront of making alarm system motion detectors that you can live with...meaning, all attempts to minimize falsing in real world settings such as the one you present. No guarantees but they are cheap enough to try. Wish I would have bought a couple more given the seller is overseas in the country that Visonic started in (before they were bought out by Tyco). Shipping & Customs was not a hassle, just took a bit.
One other idea, I have put the sensor you have in a piece of PVC pipe for weather protection. 2" PVC w/ a "bell end" houses the sensor perfectly; and then leaving a bit of the pipe narrows the view-port that is sensed. They act much more like beam sensors in that configuration. However, I can't see how that would work/look very nice on your porch wall.
Similar to comment above regarding Blue Iris, here is another option I’ve set up using tinyCAM (runs on Android) which can report motion, person, vehicle, pet and face…
Another thing to consider is whether you can apply a ‘mask’ to the scene so that motion sensing only occurs within specified areas of the camera view, to avoid problematic areas. This is something many camera apps support. tinyCAM supports this too of course, as I’m sure BI will too.
The YouTube video (by The Hookup) is a great starting point. There are pages and pages of discussion in the ipcamtalk forum (although the former and the latter think ill of each other, to put it mildly).
I was never able to control false alerts with PIR detectors but the Blue Iris + Deepstack integration to Hubitat as a pseudo motion detector has been near perfect. This is likely way more than the OP wanted, but, hey, it's another hobby.
I used 4 of the outdoor Hue sensors in the AZ heat, and am just waiting for them to get back in stock at Costco to add them to our new house in PA. Repeat business is my highest compliment.
The one sensor in AZ was pointing at a Palo Verde tree that swayed and dropped branches with mild breezes. I don't recall any false trips.
Being lazy here (as this may be discussed elsewhere)
Has anyone worked out the range and beam width at X feet of range for the Hue motions?
I don't see it in their specs on the page linked above. Are they meant to be placed in close proximity to a passage way for light triggering, or do they take a reasonably wide and far look across an area?
They hide this info, but 160 degrees side-to-side and 80 degrees vertical.
The vertical mounting height will determine your range. 7.5 feet (2.3m) seems to be about perfect to get optimal range. One video review said that the range was poor, but they tested it at waist height. With an above-door mount, 20+ feet is typical in my experience.
