Basic Rules is essentially the successor to Simple Automation. It covers the same simple “if this, then that” cases, but it’s built on the Rule Machine 5.1 engine, so it gets the better trigger and action handling. I don’t see a reason to start a new setup on SA.
Room Lighting: This is the one I’d lean on most. It handles motion/contact-triggered lighting, per-mode or time-based levels, and turn-off timers in one app, and it replaces a lot of rules you’d otherwise write by hand in RM. The learning curve is mostly in how it handles activation vs. “off when” conditions and what happens when you manually override a light. Expect a bit of tinkering on your first few rooms.
Basic Rules: Easy to learn, and fine for one trigger and a few actions. Once you need multiple conditions, private booleans, wait/repeat logic, or variables, you’re in RM territory anyway.
RM for the rest: Keep it for anything with real logic: multi-condition triggers, delays with cancel, state tracking, global variables.
I use Button Controller for all my Lutron Picos. I have many scattered throughout the house. They work great and are very reliable.
I also use Room Lighting, Basic Rules for simple automations, and Rule Machine for most everything else. One Rule Machine tip I have is to keep it simple. I may break a task down into two or more automations, rather than try to combine it into one large and complicated automation.
My 2 cents. I use Rule Machine. My logic is it can do anything the other apps can do and more. Why have multiple apps when 1 will do. I do use button controller because I have a rule in there created way back on version 1.3
For basic scheduling I like this Schedule Manager app:
Almost all other lighting automation in Room Lighting.
For the rest, if you already know Rule Machine I'd use it over Basic Rules just to be able to keep automations grouped in one place. I use naming prefixes to further group rules together.
Personally, I use custom apps for most things. I've been using custom apps for quite a while, predating the rise of AI coding agents. With the current agents, it's even more an option for more people.
I'll add Button Controllers if you use Picos. Literally all of our table lamps and shade groups are accompanied by picos on pedestals. As well as few wall mounted ones for the bedroom shades and master bath vanities
Take your time where you can, working out on a small number of situations what works best for you, then start to expand. And take the opportunity to try some of the features you haven't already.
I feel like there can be some benefits to using the same tool for the same job (or even multiple jobs), but don't force yourself to be locked into that single solution if you come across something that doesn't fit. For me, having a longer list of automations under the same app with a good naming convention can make things a little easier to find, plus there can be benefits from ease of repeating the same pattern in the same automation app. If this then becomes too much of a chore, e.g. too many of the same thing, then you can start to get into the realm of custom apps that may make that process easier.
I've ended up with mostly Button Controller, Rule Machine and Room Lighting myself, but what suits one person may not work for everyone.
