Yeah, fortunately my whole family in law are Apple fanboys/girls. So i'll be alright.
Well crap. I'll have to get the Mrs to run that on her iPad...thanks for the idea @gavincampbell!
S.
Just picked mine up last night. Setting up today. Hoping AirPlay2 will allow me to play via Symfonisk and AppleTV 4 (connected to amplifier) at the same time. Does that work?
Yup. I have about 8 airplay 2 devices in my house. From my phone I can send the audio to any combination of them. They generally keep in sync but ever now and then drift out of sync but doesn't happen often.
Hello: A general SONOS Question:
Does anyone here have a SONOS Beam? (That's the soundbar version)?
Do you connect it to your Google Home?
Can you use it as an input/output speaker for Google Home?
Yep. Just tried, but the slight delay is enough from Symfonik to Apple TV 4 as to make it unusable in the same room. Would be fine if the speakers were in separate rooms far enough away, or the Symfonik is out on the deck, which will most likely be how we use it in that scenario.
Actually itās also not letting me use Trueplay on iOS 13. Going to have to wait and use my wifeās phone.
[Edit] Forgot about the old iPhone 5 I have. Agreed, it does sound much better after Trueplay tuning. Remember to disable compression in the Sonos app if your network can handle it.
Didnāt realize you can do a sudo-group play with the Sonos speaker and Echos. Just start playing from the Alexa app to the Sonos, then switch playing to the Alexa group or speaker and it will come from all of them.
The Echo devices will be significantly out of sync from the Sonos, but it does work all the same.
Yes, but why would you ever WANT it to do that? Sounds more like a bug than a feature.
Freedom of choice
Ok...
You can definitely be free to have super echoing/out of sync sounds in your house I guess. lol
Obviously you wouldnāt do it in the same room. I also wouldnāt use airplay in the same room because the fraction of a second difference If you donāt like it and want to roll your eyes at it thatās fine. People can make choices and do it for the reasons they want to
Never said they couldn't...
You answered the question - it could be useful in different areas of the house where you may not notice/be ok with the sync issue. I didn't think of that. Thanks.
I just installed the bookshelf speakers for local TTS. Two minor points to add here;
The Sonos app does not work on Chromebooks, which is annoying since I use a chromebook as an all-in-one tablet for SH control.
If you're using Polly in your speech messages, the Sonos driver seems to have a ducking issue when it encounters a period. When switching from G Home to Sonos, I had to change periods to commas and the issue mostly resolved.
Not sure how this could be related to the Sonos driver, Our Poly implementation delivers an MP3 URL created from the TTS text to the Sonos device, the Sonos device doesn't ever see the the raw text...
Is there any special tricks getting your symponisks added to the HE sonos integration? Mine are showing up and work fine via the Sonos app, but HE is not discovering them?
Or could you paste a node red flow (if you have one) using tts so I can just bypass the integration?
That's really strange. I didn't do anything special, and the Symfonisks just showed right up.
I haven't added any Symfonisks in a year or so though, and many versions ago though, so....
You shouldn't have to cast any dark magic spells though.
S.
That's what I figured. I don't know if it has anything to do with the new S2 app that Sonos made me switch to when adding these or what is the deal I have an earlier post on a different thread on the errors being thrown in the log. But being it's an auto discovery there doesn't seem to be much I can do to correct it?
I've tried completely removing the HE integration and redoing, I've tried resetting the devices/removing them from Sonos and readding then re-discovering, no dice!
I had the same issue just a few days ago, discovery doesn't work. But you can add the speaker manually and everything will work fine. Check Cannot Find Any SONOS Speakers for details about adding the speaker manually. I am also using Sonos's S2 app, maybe the issue is related to that.
YOU ARE MY HERO!!! I've been fighting this all day, and this link you posted got them working via hubitat.
Now the dreaded pain of redoing all my tts rules that I had to delete before uninstalling the sonos integration and re-installing it.
