Sonoff Temperature & Humidity Sensor - model SNZB-02D
Swapped over to your Tuya driver, re-paired and configured advanced settings as you said and it is working flawlessly now! Super impressed :grin:
I'm assuming battery life will be considerably shorter with the more frequent reporting, but I can live with that. Got a whole drawer of 2450 batteries.
May I ask what you are using to graph your temperature sensors? That looks very handy
I am using WebCoRE graphs (the built-in Hubitat app) :
Currently, I don't have any Pistons, I use only the Graphs part, including the LTS (Long Term Storage).
Has anybody had issues pairing the 02d (display) version? After several attempts I did get it to pair and configured in the (C8) hub, but the radio icon didn't appear on the sensor display and it never reported any readings.
I've removed the device and trying to pair again - but no success.
I am using generic zigbee pairing and also trying via the known device route. Each time pressing and holding the reset button on the sensor for >10 secs.
Any hints/tips?
I didn't realize that there was a newer version. Does the 02D version offer any additional features?
Sonoff SNZB-02D has a LCD display...
@jon11 you can try the 'Double Luck Voodoo' to pair the device to your C-8 hub.
@vmsman This is the first one I have bought - so can't tell you if it has additional features. that it is exactly the same, it just has an LCD display of its current readings (and an inability to pair effectively from what I can see).
