[Solved] Sylvania Smart+ RGB light strips not changing color
I bought a couple Sylvania lights a few weeks ago and I just got them today. I pulled out one and plugged it in (powered on and color cycled then turned white) and was able to get it added to the Hubitat right away. I then added the device as a color bulb in the dashboard, but whenever I try to change the color, nothing happens. I tried this with the other package, and I get the same issue.
I can fully control the LED lights, power on and off and dim through the dashboard, but I cannot change the color to anything other than white. Does anyone know why this would be happening? I only have the Hubitat and these light strips and Hue hub with a couple Hue bulbs (everything else seems to be working, just not the color for these LED strips.)
Which driver are you using? I have had success with the Generic ZigBee RGBW Light driver.
That’s what I’m using as well
It just defaulted to the Generic ZigBee Bulb driver. I didn't even know you could changed the drivers. That solved it! Thank you so much!
Good to hear! There have been some good deals on these lately and they have worked well for me so far. Glad to hear you have it working.
Yeah, I got them for $17 each, and now that it's up and running properly, I'm extremely satisfied with it.
I bought 5 of the 16' Sylvania Flex XL RGBW strips and really like them so far. I put them around the inside trim in the closets and pantry with ceiling motion sensors so if you get close to it, or wave a hand in, the light comes on. Not as bright as the Hue lightstrips, but bright enough, especially for the price. They have a firmware update that seems to be only available through the Lightify gateway btw that seems to improve reliability.
