I'm trying to execute a HTTP Get between (2) times of day if at least (1) presence sensor is present. For some reason the rule is not being executed. I can manually run the action and it works fine. Below outlines how the rule is configured. Any advice would be much appreciated.
Select Trigger Events
Each of these minutes: 5
Select Actions to Run
Send GET to: http://xxx.xxx.xxx.xxx:xx/adming?profile=7&user=xxxx&pw=xxxx
Manage or Create Conditions
Time between 6:00 AM PST and 10:00 PM PST TRUE
Presence_Sensor_#1, Presence_Sensor_#2 any present TRUE
