Just added a GoControl WA00Z-1 ZW+ successfully to my setup. Works just fine with the Generic Z-Wave Button Controller. (Not HE's fault, but this is one ugly device, but I needed it!)
My issue is that the device driver is only reporting 1 button:
But as can be seen from the screenshot, I pushed button #2. There are in fact 2 puttons to press on this device.
If I use this device in RM, I can successfully use a Custom Attribute to detect which button is being pushed.
However, If I try to use / configure a RM4 Button Device, it only ever gives me the option to do "things" for 1 button. I suspect because the driver is only reporting 1 button available.
Is this a bug in the HE driver? Mike (@mike.maxwell), I suspect a question best addressed to you.
I'm new to Hubitat. I bought a GoControl WA00Z-1 to use controlling lights. I've added it as a device and set the type as generic button controller. I'm not having much luck using it though. Could you tell me how you set up yours?
I just set up this button using the instructions here. That's after I added the 2nd button using the tip from @mike.maxwell. Thanks. For the newbies like myself who arrived here via a search, you need to use a button app to get the button going. Follow the instructions above. Everything works great. Don't be alarmed if it doesn't work immediately. Give it a minute or two after you close the menus in HE.
I migrated from Wink when they went to the subscription model and it was a bit different to get everything going but I am really happy I did and I have never looked back. I have between 70 and 100 devices connected to my C5 HE hub and I have just purchased a C7 to work with European frequencies (C5 is NA). Looks like there aren't too many Z-Wave bulbs left in the American market. Thanks for the great community.
I switched from generic z-wave button controller to virtual button and then saved. Set physical buttons to 2 and saved. Then changed back to generic z-wave button controller and saved. The numberOfButtons stayed as 2.
The temporary Virtual button trick worked for me too. I did need to delete the existing Button Controller app instance I had for it andncrea5e a fresh one though. No biggie since I needed that second Hutton accessible in the app to finish installing it anyway. Thanks!
