This is my first post here and I'am a Hubitat home elevation user from New Zealand.
I would like to get some guidance on setting up my 2 Aeotec nano dimmer (Gen 5, 921.42Mhz) with Hubitat.
I tried the following steps (from: Join and Reset Instructions - Hubitat Documentation) to reset and join/discover my two dimmer in Hubitat:
- Factory Reset
- Paired by standard security i.e. single press button
- Paired by secured i.e. double press of action button
But still, Hubitat failed to discover the dimmer.
I'm not too sure if I missed something. Because when I searched the forum, it looks like everyone have a success of setting up their Aeotec Nano Dimmer with Hubitat.
Also, is there a way for me to tell if the my hubitat elevation is actually the AUS/NZ version? as I just want to narrow down what might be the root cause of this problem.
Do you have an external USB stick connected to your Hubitat? That has the region-specific zwave radio. The internal zwave radio is North America specific.
Yeah, safety shut down your hub and attach the dongle that should have came with your hub. You can then confirm on the box of the dimmer what frequency it is.
Also, try excluding the dimmer first. Often times, z-wave devices will shit having been paired for QA check before leaving the factory. When in doubt, exclude it first.
I don't know if my experience with a MultiSensor 6 is the same as yours (it is an Aerotec product) but....
Yesterday I tried to pair a Multisensor 6 with no luck. I must have tried 10 - 15 times no luck. Finally I just left it powered on the desk for about an hour, came back and it paired the next try. I don't know why but I suspect I was retrying to pair too quickly and the poor controller in the device got lost
BTW I'm in the US.
Kia Ora, mate.
How far are the dimmers away from your HE ??
Are they in metal back boxes, behind switch plates or located at the lights ?
Are these the first devices your pairing ?
The Zwave stick is the stick that came with the Hubitat elevation hub, no label of the Zwave frequency if that's what you're looking for. (see attached photo)
That’s a bummer there’s no label on the dongle.
Under settings on your hub, Zwave radio is turned ON, eh ??
Think its probably time to get Support or @bobbyD involved.
No probs.
Seems weird that there’s no label on the dongle, especially for international customers.
Of course the time zone for us, for Real-time support, is not the best but they’ll get you sorted.
But try changing the secure Zwave setting as that causes extra traffic etc
Based on the user manual for the aeotec dimmer, when you pressed the action button once when in pairing mode the comms to the hub will be unsecured. But I have no way of testing that because it’s not even pairing/discovered by the hub.
