Title says it all. I did try air gapping the dimmer right before my 2nd attempt to update. Same results.
Looks like that might be fixed in the hotfix [2.2.4.147] that just was made available.
Tried 2.2.4.147
I walked away so I didn't see any error messages but the device was not updated.
UPDATE: Removed and repaired the dimmer, using the bravenel method for transferring devices. C4 to C7.
The ZEN27 finally showed the updated revision.
Sounds like a job for superman...er @bcopeland
