I base my watering on previous and expected rainfall.
I use a kind of ‘weighting’ to allocate a value to each figure then do a calculation of the numbers to produce a final figure.
If that figure is below a certain number I’m told by HE to water the garden
Another user uses then same calculation to turn on his water...
I have the Spruce Moisture Sensors but haven't integrated them yet, i've been trying to run a bare bones hub for a few weeks to work out what was causing it to crash. I'll be adding them soon to a secondary (non-essential devices) hub.
Smartthings is a lot easier as it has built in get weather commands which Hubitat does not. I have written my system using a local temperature device and openweathermap for the forcasting. You will need to get an API key from openweathermap, their basic package is free.
Thanks, but I want to automate the watering of a covered salad beet. If the soil is to dry give water for x seconds.
But I asume your App is great for lawn.
Ambient Weather has released a soil moisture probe that works with their API. It works with their ObserverIP unit or with a small display console that uploads the data to Ambient Weather. The existing Ambient Weather app could be updated to provide that sensor data.
You will need to change the code slightly. Replace mentions of switch with valve ie input "sprinkler", "capability.switch" should now read input "sprinkler", "capability.valve". The handlers switchOn line 303 and SwitchOff line 311: you should change and sprinkler.on() and sprinkler.off() to sprinkler.open() andsprinkler .close().
The temperature measurement is just a number from your local temepraturemeasurement device, just change the "C" for an "F" in the app.
For the forcast, the temperatures are read in K and converted to C by the lines
def maxToday = weatherNow.main.temp_max - 273.15
def minToday = weatherNow.main.temp_min -273.15
you will need to change that to def maxToday = (weatherNow.main.temp_max - 273.15) × (9/5) + 32
to convert rain from mm to inches the lines before need changing
def Rain24H = "$forcastRain" / 25.4
Might be a little off topic due to the Bluetooth range limitations, but the really inexpensive Xiaomi Mi Flora sensor looks interesting. There are Homebridge, Home Assistant and MQTT implementations using the BLE from a Raspberry Pi
this is my current working version: I had a problem last night, the internet must have been a bit flakey and the httpget timed out, as a result the weather forcast information was NULL and the app failed to work. I am working on a retry if httpget fails and after a few attempts just assume all is ok for watering.
Did you ever get the spruce sensors up and running? I’m planning on using hubduino with moisture sensors attached if I can get it stable and waterproof to go outside. It’s too late in the season this year so at least I have time. Lol
Not who you asked, but I happened to get my new v3 Spruce sensor up and running. Just put it out in the garden about a day ago, and it's giving me some readings (graph came from Home Assistant--wish there was an easier way to do this):
The Spruce manual says "generally, soil moisture will range from 10% to 45%, but can be higher during and after watering." The spike in this graph is when I watered, where it reached barely 40% before dropping more or less exponentially and tapering off down to 12% (I think I started around 3% or 4% before watering).
I don't know how to interpret the readings yet. The manual says it depends on your soil type and how well the sensor probe makes contact with the soil. I started with about 5 days with no watering or rain, so we'll see how long it takes to get back to that level if the weather doesn't have other ideas first, I guess, and see if I can really use this as a good gauge of when I might need to water the garden based on my own habits and recent rainfall.
