I looked in many threads and I didn't find an answer to the problem if the axis working in this sensor. My reports temperature fine. It reports open/close with the magnet. But if I switch to garage mode (either of the 2 options) it doesn't report on the tilt. It doesn't matter which way I tilt it. And it doesn't matter if I have the contact attached to it or not. Of course, the way it was working it was no attached. It was just the tilt based on the axis.
I moved this from ST last night. It was working on ST. Here are two screen prints.
Any help will be appreciated. Thank you in advance.
It looks like you have the option to disable xyz events set to active, ie xyz events are off.
Change the βdo you want to use this sensor on a garage doorβ toggle to βnoβ and then click the configure button to send the new configuration to the device.
Thanks Mark. But unfortunately, as I mentioned in my post, I've tried both. None work.
Do you have one that works? Maybe something happened to mine when I disconnected from ST and connect to HE.
Okay good. I was just wonder at the fact that since we are at 2.0.4.118, if there were going to be more after the .4. I guess basically I was trying to determine how long more or less it would be. I'm a developer myself so I hate giving deadlines that I might miss or that I'm not be sure about so that's why I worded the question as I did
Did you join this fresh on 2.0.5?, or just change the driver...
If you just replaced the driver you need to click configure so the correct initialization configuration is sent to the device.
