I set up a small matrix up of drivers and the response of the tiles in Sharptools using Double Height Thermostat (DHT) and Single Height Thermostat (SHT) Tiles. I manually adjusted the temp on the thermostat and reviewed the results in the Events tab of the device (in HE) and the two tiles side by side in Sharptools.
I used the following drivers;
- Sinope TH11224ZB (4KW) Thermostat
- TH112xZB Sinope Thermostat EngeryMerter V3
- Sinope TH112XZB Thermostat
Drivers 2 and 3 changes were tracked only on the DHT, the SHT remained at 17 C. The Events tab (when refreshed) reflected the changes.
Driver 1 caused both DHT and SHT to change when the thermostat was set manually. The events tab (when refreshed) reflected the changes.
I would prefer the SHT so I will be using driver #1, appreciate the help from all.
/r
B
