@mike.maxwell , I think this is for you. ![]()
I was just going to order another Sinope Tank Level gauge for my fuel oil tank.
So, I was looking at the logs. Temperature reporting is as I specified: every 10 minutes.
However, there is only one report on tank level since I restarted the hub, along with a soft reset/log purge, naturally, at 8 PM last night.
This is on a generator propane tank, and the level hasn't changed.
@mike.maxwell , I remember you modified the driver to filter out some bogus readings..e.g., 0% and 83% readings.
I don't have more extensive logs because of my log purge, but can you tell me what's going on? Will it be reporting at some % change and/or every 12 hours or so?
Thanks.
dev:15212024-01-05 06:57:43.302 AMinfoPropane Tank Monitor temperature is 15.1°F
dev:15212024-01-05 06:47:43.995 AMinfoPropane Tank Monitor temperature is 14.9°F
dev:15212024-01-05 06:37:44.685 AMinfoPropane Tank Monitor temperature is 14.6°F
dev:15212024-01-05 06:27:45.380 AMinfoPropane Tank Monitor temperature is 14.2°F
dev:15212024-01-05 06:17:46.060 AMinfoPropane Tank Monitor temperature is 13.9°F
dev:15212024-01-05 06:07:46.733 AMinfoPropane Tank Monitor temperature is 13.5°F
dev:15212024-01-05 05:57:47.490 AMinfoPropane Tank Monitor temperature is 13.2°F
dev:15212024-01-05 05:47:48.103 AMinfoPropane Tank Monitor temperature is 13.3°F
dev:15212024-01-05 05:37:48.782 AMinfoPropane Tank Monitor temperature is 13.9°F
dev:15212024-01-05 05:27:49.468 AMinfoPropane Tank Monitor temperature is 14.1°F
dev:15212024-01-05 05:17:50.176 AMinfoPropane Tank Monitor temperature is 14.1°F
dev:15212024-01-05 05:07:50.859 AMinfoPropane Tank Monitor temperature is 14.2°F
dev:15212024-01-05 04:57:51.581 AMinfoPropane Tank Monitor temperature is 14.3°F
dev:15212024-01-05 04:47:52.246 AMinfoPropane Tank Monitor temperature is 14.2°F
dev:15212024-01-05 04:37:52.934 AMinfoPropane Tank Monitor temperature is 14.2°F
dev:15212024-01-05 04:27:53.607 AMinfoPropane Tank Monitor temperature is 14.2°F
dev:15212024-01-05 04:17:54.285 AMinfoPropane Tank Monitor temperature is 13.7°F
dev:15212024-01-05 04:07:54.971 AMinfoPropane Tank Monitor temperature is 13.0°F
dev:15212024-01-05 03:57:55.661 AMinfoPropane Tank Monitor temperature is 12.4°F
dev:15212024-01-05 03:54:07.666 AMinfoPropane Tank Monitor battery is 100%
dev:15212024-01-05 03:47:56.325 AMinfoPropane Tank Monitor temperature is 12.2°F
dev:15212024-01-05 03:37:56.998 AMinfoPropane Tank Monitor temperature is 12.2°F
dev:15212024-01-05 03:27:57.670 AMinfoPropane Tank Monitor temperature is 12.4°F
dev:15212024-01-05 03:17:58.322 AMinfoPropane Tank Monitor temperature is 12.6°F
dev:15212024-01-05 03:07:58.990 AMinfoPropane Tank Monitor temperature is 12.6°F
dev:15212024-01-05 02:57:59.681 AMinfoPropane Tank Monitor temperature is 12.6°F
dev:15212024-01-05 02:48:00.337 AMinfoPropane Tank Monitor temperature is 12.7°F
dev:15212024-01-05 02:38:01.011 AMinfoPropane Tank Monitor temperature is 12.8°F
dev:15212024-01-05 02:28:01.694 AMinfoPropane Tank Monitor temperature is 12.9°F
dev:15212024-01-05 02:18:02.379 AMinfoPropane Tank Monitor temperature is 13.0°F
dev:15212024-01-05 02:08:03.068 AMinfoPropane Tank Monitor temperature is 13.0°F
dev:15212024-01-05 01:58:03.767 AMinfoPropane Tank Monitor temperature is 13.1°F
dev:15212024-01-05 01:48:04.444 AMinfoPropane Tank Monitor temperature is 13.3°F
dev:15212024-01-05 01:38:05.134 AMinfoPropane Tank Monitor temperature is 13.5°F
dev:15212024-01-05 01:28:05.822 AMinfoPropane Tank Monitor temperature is 13.5°F
dev:15212024-01-05 01:18:06.525 AMinfoPropane Tank Monitor temperature is 13.5°F
dev:15212024-01-05 01:08:07.207 AMinfoPropane Tank Monitor temperature is 13.5°F
dev:15212024-01-05 12:58:07.920 AMinfoPropane Tank Monitor temperature is 13.6°F
dev:15212024-01-05 12:48:08.581 AMinfoPropane Tank Monitor temperature is 13.7°F
dev:15212024-01-05 12:38:09.265 AMinfoPropane Tank Monitor temperature is 13.7°F
dev:15212024-01-05 12:28:09.953 AMinfoPropane Tank Monitor temperature is 13.8°F
dev:15212024-01-05 12:18:10.636 AMinfoPropane Tank Monitor temperature is 13.9°F
dev:15212024-01-05 12:08:11.343 AMinfoPropane Tank Monitor temperature is 14.0°F
dev:15212024-01-04 11:58:12.140 PMinfoPropane Tank Monitor temperature is 14.1°F
dev:15212024-01-04 11:48:12.745 PMinfoPropane Tank Monitor temperature is 14.3°F
dev:15212024-01-04 11:38:13.427 PMinfoPropane Tank Monitor temperature is 14.3°F
dev:15212024-01-04 11:28:14.120 PMinfoPropane Tank Monitor temperature is 14.4°F
dev:15212024-01-04 11:18:14.806 PMinfoPropane Tank Monitor temperature is 14.4°F
dev:15212024-01-04 11:08:15.485 PMinfoPropane Tank Monitor temperature is 14.5°F
dev:15212024-01-04 10:58:16.200 PMinfoPropane Tank Monitor temperature is 14.7°F
dev:15212024-01-04 10:48:16.896 PMinfoPropane Tank Monitor temperature is 14.8°F
dev:15212024-01-04 10:38:17.600 PMinfoPropane Tank Monitor temperature is 14.9°F
dev:15212024-01-04 10:28:18.281 PMinfoPropane Tank Monitor temperature is 15.1°F
dev:15212024-01-04 10:18:18.954 PMinfoPropane Tank Monitor temperature is 15.3°F
dev:15212024-01-04 10:08:19.669 PMinfoPropane Tank Monitor temperature is 15.4°F
dev:15212024-01-04 09:58:20.402 PMinfoPropane Tank Monitor temperature is 15.6°F
dev:15212024-01-04 09:55:37.590 PMinfoPropane Tank Monitor tank level is 75%
dev:15212024-01-04 09:48:21.110 PMinfoPropane Tank Monitor temperature is 15.7°F
dev:15212024-01-04 09:38:21.835 PMinfoPropane Tank Monitor temperature is 15.7°F
dev:15212024-01-04 09:28:22.545 PMinfoPropane Tank Monitor temperature is 15.9°F
dev:15212024-01-04 09:18:23.268 PMinfoPropane Tank Monitor temperature is 16.1°F
dev:15212024-01-04 09:08:23.988 PMinfoPropane Tank Monitor temperature is 16.4°F
dev:15212024-01-04 08:58:24.712 PMinfoPropane Tank Monitor temperature is 16.6°F
