@Cramezul - Mike just confirmed that the next big update (v2.3.2) will have a dedicated driver for the newer sinopé dimmer DM2550ZB which will support double tap. You're SOL with the DM2500ZB unfortunately.
Hi @mike.maxwell,
After upgrading to 2.3.2.128 and using the new DM2550ZB driver, it looks like my dimmer is more stable really less flickering. But it seems like there is now new min/max limits for bulb level. I mean, with the previous driver the ligths would turn off at arround 10%. Now I can go down to 1% but the ligth is still as brigth as it was before at maybe 15%. Brigter than what I usually set in the Home Theater.
I tried changing the dimmer phase but didn't see any difference.
I know that the Neviweb interface allows to enter lower/upper boundaries. Are these values used in the new driver and if yes, could they be user adjustable?
EDIT: I just looked at the logs after hiting Configure(). I receive this message:
dev:3362022-06-23 21:49:52.798 errorgroovy.lang.MissingMethodException: No signature of method: static com.hubitat.zigbee.message.ZigBeeMessageBuilder.getMsgType() is applicable for argument types: (java.util.ArrayList) values: [[zdo unbind 0x110A 0x01 0x01 0x0008 {500B91400003D3A1} {}]] Possible solutions: getMsgType(java.lang.String) (method configure)
EDIT2: Save Preference doesn't seem to work all all. The Indicator color will not change no mather which color I choose
I created a new Topic to follow up on these issues...
