I have 2 Sinope DM2550ZB dimmers. Since the release of the new driver in v.2.3.2 I've got some issues and they behave differently.
First thing first, since this driver, they look more stable. Less flickering, That's awesome!
1- The first dimmer I converted to the new driver seems to now have some kind of min/max boundaries. Before, the light would turn off to around 20%. Now I can go down to 1% and it's still stays on. But this 1% is still brighter than what I would normally set in the home theater. My second dimmer doesn't behave this way, it would still turn off around 20%.
1.a- I know that Neviweb has an option with the DM2550ZB to adjust the minimal dimming value. Could this option be made available to HE?
2- The devices preferences don't seem to save and update. If I change the indicator color and hit Save preferences nothing happen. The dimmer phase doesn't seem to change nether.
3- When hitting Configure an error is logged
dev:3362022-06-30 23:24:41.918 error groovy.lang.MissingMethodException: No signature of method: static com.hubitat.zigbee.message.ZigBeeMessageBuilder.getMsgType() is applicable for argument types: (java.util.ArrayList) values: [[zdo unbind 0x110A 0x01 0x01 0x0008 {500B91400003D3A1} {}]]
Possible solutions: getMsgType(java.lang.String) (method configure)
dev:3362022-06-30 23:24:41.845 trace refresh()
dev:3362022-06-30 23:24:41.797 warn configure...
@mike.maxwell can you help?
