Search Term: " two switch single gang smart switch"
None of those are zwave or zigbee. All wifi
Im having fun with the Sylvania 73743 dimmer buttons, works great! Its zigbee and single-gang. Its not very conventional or intuitive maybe, but you could have the top button press-on press-off for light #1 and the bottom one for light #2.
What about two Lutron Aurora dimmers and smart bulbs?
I will be buying a few Auroras, but unfortunately one of those switches is a low voltage undercabinet light so no option of using smart bulbs
At the risk of sounding like a Sylvania fanboi today, these are a fantastic value
Don't know of any switches like that, either zigbee or z-wave. But I can vouch for the qubino dual flush relay. I know you didn't want to but I had the same problem, and it worked well
Try looking at this one, can be sourced from china:
https://www.amazon.com/NEO-Coolcam-Sensitive-Automation-SmartThings/dp/B07F9Z6YK3/
Now apparently supported in Hubitat:
For anybody coming across this in 2021
This is the only 1 gang 2 switch zwave I have been able to find besides the neocool. The neocool looks ok but it is a very different design and I have a lot of traditional looking Leviton zwaves throughout the house
Yep, the Zooz are pretty popular around here. There is a built-in driver for it.
So the Zooz Zen30, which I have in all my bathrooms, is a dimmer/switch combination.
If you need two switches and want to retain the Decora look, then there is the option of using an in-box zwave dual-relay, such as this one, which are Hubitat-compatible, and can also be controlled by regular single-pole switches.
The Enerwave dual-relays, that I linked to, support a load of up to 10A per relay. I have a couple of them in my z-wave network and they worked very well.
Aeotec double relay + Aeotec swipe (both on Amazon).
Pricy but looks good and works fine.
Tested and fully functional.
