LOL They have a pretty big file on me...
I think they have a large file on Rick...
HR has a separate filing cabinet for him.
Might be a small warehouse
Think they’re moving to digital storage with an inital implementation measured in petabytes…
Ok son helped me lift servers into rack during thanksgiving.
Rack upgrades complete. Thanks for the ahem prodding to neaten my office and the hole in my wallet.
Holy crap, is that a router or a starship?
those are two routers.. main and backup bechind it i can switch in for failure.. obviously and unfortunately cannot put routers in the faraday cage
Get extension cables with clamp mounts. You can clamp the, around the perimeter of the rack
It's W.O.P.R - would you like to play a game Dr. Falken?
How about a nice game of chess?
A few of these on mounted on the outside top of the rack with antenna extensions
Here is the other type of rack. Old school wired zones with a mix of old (Yamaha mx-1000 recapped 80s vintage amp with newer 2nd amp and yamaha flagship preamp with zone selection via wifi/app) Anyone else running a similar setup?
Is there a particular name for those brackets? I might want those but can't find them
A Google search of "antenna L bracket" seems to get good results.
My humble submission is still a work in progress, but an improvement over having various devices scattered across a table.
This weekend, I relocated power and coax to allow everything to have a fixed (if not proper) home.
- Arlington TVBU507 recessed outlet wall plate kit
- Eaton TR7765W outlet with dual USB (HE plugged in directly)
- Cabinet cutouts - access to wall plate and pass cables between sides
- 3 x 3/4 "Smurf tube" conduit to the attic for future runs of network cable.
- Unifi Cloud Key for cameras - currently only pulling data from Wi-Fi cameras.
- Network switch (POE) - not yet connected, just stuffed in there
There is still plenty of work to be done, but the room can now be used for holiday guests. Separating HE power means that it will be unaffected when my wife's laptop drops off Wi-Fi and she flips the outlet strip switch to reset it..
I gotta get some Rackstuds like you have. So much cleaner!
What are the three 1u devices under the printer?
You have redundant DACs for the 48pro or are they going to other things?
