I have a dashboard that I access from a chrome “add to home screen” window, and I’ve noticed that a weather jpeg tile tends to get “stuck.” Other tiles with local devices and sensors don’t seem to get stuck. It’s a fire tablet, but a 2015 model so it’s rooted and running cyanogenmod OS.
I don’t run into the same issue when I access the dashboard from a tab in safari on my iPhone (although that’s obviously reloading the whole page each time I bring that tab to the foreground).
Thanks. I'll see if I can recreate the issue on mine. I use it for testing releases and haven't seen a stuck tile. However, if the tablet has weak wifi, and drops a packet with the update, the tile will be "stuck" until the 5 minute refresh occurs.
You can change the position (row/column) of any tile. You can also set the size of any individual tile.
So depending on the number of tiles you want to center, you simply add an additional row/column...and/or stretch the tiles across one or more rows/columns.
Hi, on your DAKboard tablet, Go into Settings, Web Content Settings, Start URL...this is your HE Dashboard URL. Then go into Screensaver playlist and add in your dakboard URL. You will also find the screensaver timeouts and tons of other options in settings (like motion).
You can change what is on your screensaver by visiting the DAKboard website. Should find them under the screens, background tab. Can also add weather, calendars and more.
