Shelly products
G'day all, for those wanting to use Shelly Dimmers with a lamp (eg bed lamp) I've just published a Compact case design that allows you to have it installed in-line on a 2-wire lamp cord.
ps, Make sure you get your sparky to inspect or install it if you live in a jurisdiction that requires it.
Doesnt the dimmer get hot? I have a dimmer that pushes that its to hot after a while on and its mounted in a tight space
It has some ventilation through the sides where the wires pass through - but no they don't get very hot or I'd have printed them in PETG instead of PLA.
Hi all
Is there a way to use a Shelly WiFi Motion sensor with my hubitat hub?
I am looking for a motion sensor that can report illuminance level.
I am getting bored of changing the batteries in my Aeotec Multisensor...
thank you
Yes there is... just have to look at the repo GitHub - ShellyUSA/Hubitat-Drivers: Device Handlers To Use Shelly Products With Hubitat
See above
Hi @Evilborg
the EM shelly has arrived and I have installed it
The drive works correctly
I have a few questions:
  1. can i change the control power from HE?
  2. is it possible to detect the switch change immediately using the
    OUTPUT SWITCHED ON/OFF URLs (like Shelly WiFi Switch)?
  3. is it possible to catch generic http messages?
    to use for example these ?
Thank you very much for your work
@roberto.grosso.rgr the driver is what it is. In other words I'm not actively working on it and its opensource so anyone can change or add anything they want.
@anon81541053 all Shelly devices that are battery operated are MQTT only. It saves battery life.
I ordered 2 and they have just arrived.
Is there a way to make sure the hue motion sensor firmware is up-to-date without a Hue Bridge?
thank you.
Pairing out the box was easy and reporting motion and illuminance is quick
Good suggestion from the community
Off-topic -- please stay on topic
Anyone here had issues with Shelly Dimmer 2's dropping off the network if your router reboots and takes down your Wifi?
In the FB group people have made comments about this with the newer firmware. Not sure if its being addressed or not yet.
Oh good, it's not just me then.
Yes, I am have a shelly 1 amd rgbw2 fall off wifi, a second shelly 1 is fine, but all work in my dashboard, strange.
Shelly products - Has anyone ever used a Shelly product to control the speed of a harbor or Hampton Bay room ceiling fan. Would the new dimmer do this task?
I tried using the dimmer to control a pedestal fan and it made strange humming noises so I dropped the idea.
I wouldn't recommend it.
Can you please send me instructions on how you set it up..
I have it in front of me but I'm not able!to work out how to add it.
Thanks in advance
  1. Add it to shelly app.
  2. Set fixed IP in your router (or in shelly app - but not recommended).
  3. Create virtual device - switch in HE and save it
  4. Select Shelly driver for plug in created VD and enter its IP address from point 2.
  5. Test it and enjoy it :slight_smile:
