Shelly products
Hi all - long thread! =p
Just hoping if someone could give an answer in a nutshell.
This product (https://www.amazon.co.uk/Shelly-shelly-dimmer/dp/B07XRY1K7V/ref=asc_df_B07XRY1K7V/?tag=&linkCode=df0&hvadid=430958538413&hvpos=&hvnetw=g&hvrand=9154902158048989270&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1006816&hvtargid=pla-847159398915&ref=&adgrpid=102794385289&th=1) Shelly Dimmer 2...
  1. is it easy enough to get woking in hubitat?
  2. Is it local control or cloud reliant?
  3. Can I use it in place of a fibaro dimmer module? I have my fibaro hooked up to a retractive switch and it still works awesome, but I'm not paying top price for more of those things if I can avoid it.
  4. If wifi/hub drops out, does the shelly work anyway as a dumb dimmer (again, fibaro does).
Much appreciated!
  1. Yes
  2. Local, but you can use shelly cloud if needed
  3. Yes. I did it recently and works perfectly.
  4. Yes, same as fibaro.
Awesome. Thanks!
Hi, another vote for the Shelly dimmer from me, I have 3 and they work very well....a lot better than the LightwaveRF dimmers they replaced.
I can also vouch for the dimmers. I initially had trouble with flicker but playing with the trove of options allowed me to sort it out. I think that's the key with these - the myriad of options allows you to set it up exactly how you like it.
Hi
I would like to buy a Shelly EM I am in EU
What driver can I use to read the power consumption?
@Evilborg can you help me?
I have Shelly EM3 and it works with Shelly Switch relay driver. However the refresh rate is very low (1 minute) when comparing to integration with HA or Homey where it was instant. If I do poll/refresh device, it gets new values, but then its consuming quite a significant resources of HE.
where i can finf the @anon61068208 drivers?
Tagging @Evilborg
@Evilborg's drivers are now the official Shelly drivers for Hubitat, and can be found at:
Tere is no configuration on the webpage of the shelly that help with this delay?
No, I believe this is most probably driver specific. Within driver, you can select refresh interval of 1min up to 30 minutes or manually/polling. This will however refresh all device information and I think its causing the load for system. Shelly device itself is updating instantly, same the Home assistant using shelly device and same Homey, which I was using before HE.
are you suggesting that I should look for a non-shelly device?
Are there power meters (not plugs) that I can mount inside wall boxes?
Depends what you need it for. Shelly reporting and device itself is reliable. But its not as instant as with other controllers (this is not shelly fault). But even if you do manual (or RM) refresh every 15 seconds, HE can handle it and you get almost the same result.
the purpose is to prevent the main switch from switching off due to too much power consumption.
I have asked about Shelly EM with clamp, but i had no useful anwer.
For some appliance i use smart plugs. for others i need to put the device in the wall box, and shelly 1PM was my first idea.
Note: Sorry for my English
https://shelly.cloud/
This is proof that my English is bad :slight_smile: :confounded:
Thanks @Evilborg
Sorry
I wanted to know which driver was needed to correctly read the power of Shelly EM .
and if the drivers "ShellyUSA" work for the EU devices
SAme question for Shelly 1PM too :slight_smile:
I realise now...
Refresh with RM?
How can I do this?
You create new rule in Rule Machine that will be triggered e.g. every 15 seconds and action will be device refresh/polling.
Shelly Switch Relay -- you should actually read the notes I put in my drivers.
Sometimes my search for information takes convoluted turns. :upside_down_face:
