Shelly not working correctly
Hi,
I'm facing some problems with shelly connected to hubitat, I have add shelly 2.5 and 1pm and dimmer to hubitat through virtual device and add the iP address. When I go to devices in hubitat I see the devices. I add the devices to dashboard but when I click on the device to turn it on it stuck on sending, what I missing here, why that happening?
The event is not showing in the logs untill I hit refresh incide the device.
Having similar problem. I have two Shelly Dimmer 2 installed, both added as virtual devices in HE the same way, both show up on dashboard. One of the dimmer does not respond to any command but the other is working as expected. I have tried the REST API on both and that is working fine. I have tried to reinstall the device several times with different names without success. I'm using the official "Shelly WiFi Dimmer" that came with an HE update lately.
I find a solution here:
or you can type it manually from this post:
Thanks @mousawm, it worked to manually set the action URLs.
Hi there.
Can you explain to me how did you do it exactly?
And is your method based on local control?
