Rather than re-inventing the wheel is there driver code for Shelly on off switches I can adapt to use the Shelly Wi-Fi based Door & Windows Contact Sensor with? I've looked all around and did not see anything like the pre-programmed device drivers that are hard coded in Hubitat already.
You may want to look into the Shelly drivers in this thread, I am using drivers from @tomw testing out a couple of Shelly Button1's
The Shelly contact sensors look cool @coreyclerico. When I looked at their API a while ago, it was prerelease and they did not have nearly as much functionality as they do now.
My drivers that @ronv42 linked to do not support the contact sensor yet, but I could take a stab at adding it if you would want to test it when complete.
