Sensor to detect standing at the top (or bottom) of the stairs
I have a split-level house, so my entry door opens onto a landing halfway up the stairs between my house.
I'm planning on installing very soft lighting to help navigate the stairs in the dark, and I want to use some sort of presence sensor to turn it on.
Originally, I thought I would use a normal motion sensor. However, I find that it's too good at detecting motion, so it tends to see me as I walk around in the living room upstairs.
I was wondering if anyone makes a very narrow beam-like motion sensor, which I could install near the top and bottom stair, so that the lights would only come on when you're literally standing at the top or bottom.
Does anyone know of such a sensor, or have other ideas how to resolve it?
I haven't tried it, but I hear others have. Make a tube and attach it to the front of the motion sensor. Depending on the length of the tube it should narrow the active zone smaller.
See pics at above - gives you an idea of what @Slate is talking about.
Anything you do that blocks enough of the motion sensor's field view will accomplish what you're looking for.
One other option, Nyce NCZ-3045-HA ZigBee Curtain Motion Sensor.
Only $200?
:wink::rofl:
Ah, only $53. Ouchie! :face_with_monocle:
I simply position mine slightly behind or underneath something to restrict the area the sensor detects. I have one at the top of my stairs situated on the floor behind one of the posts for the handrail, pointing towards the adjacent wall, so as not to pick up movement in the room.
This is exactly what I needed to do also.
No complication needed. Dumb pirs with a bit of electrical tape over part of the sensor. Works ace. Has done for about 6 years.
One failed once, and I replaced it for about a tenner.
I use electrical conduit bushings to limit the field of view. They are cheap, and match the plastic of most of these sensors fairly well. I just put a dab of hot glue on them to hold them in place. https://www.homedepot.com/p/Commercial-Electric-1-2-in-Electrical-Metallic-Tubing-EMT-Insulating-Bushing-4-Pack-FEBIP-50-4/316098195#overlay
Electrical tape comes in colors now. I use the white version in a couple of places.
I'm thinking, try restricting the aperture with the tape first, because it's easy to reverse.
I'd say get the white pipe bushing instead of the gray for a white sensor, like the Hue.
And, make sure the arrangement works before hot glue-in, or make an extendable one like @mike.maxwell did.
I have several Nyce sensors. Pricy? Yup, but they work flawlessly and the battery lasts a long time in all of them.
Since my basement has invisible dry wall I've learned the art of taping motion sensors.
My favorite, attach w/Elmers and stays attached, but also easy to remove/change later.
So it looks like this? :wink: Seriously, what the heck is invisible drywall?
That's it only filled with 30 years of junk.
Ah, so over time the junk becomes the dry wall. ("Be the dry wall!") :wink: Very Zen...
The problem was the sensors were on the ceiling (joist) and the junk is mostly chest high so far. :grinning:
+1 for the NYCE curtain sensors. I use a couple in one of our staircases. I put them at the foot of the stairs. Works well and inconspicuous. Use command strips so if they are dislodged they can easily be put back
NYCE in it's cubby. Works great to trigger my under-rail LED strip is activated so my 16 year old dog can see well enough to get up the stairs.
It ends up looking like this:
That motion sensor is facing into the kitchen and is used to turn on the undercabinet/overcabinet lighting, but I didn't want it turning on when I walked past the doorway (90 degrees from this sensor). It works perfectly for limiting the motion detection to the angle I want.
Holy crap! Your house is upside down - Hold On!!!
:wink:
Impressed - you actually made a cubby/shelf for the sensor?
