Part of the reason for my inquiry as not sure what is current and correct. What are some easy ways to do this? Thanks for the help!
I am actually working on extending my Google Calendar Search application to include a Gmail notification device option as well as email searching capabilities. This solution will not require a middle man mail server and your hub will work directly with the Google API's to send the email.
I should have a version posted this week. I will tag you once I get it released so you are aware. The Google API setup can be a bit tricky but once setup you shouldn't have to mess with it again.
Excellent! I look forward to another great addition!
I just uploaded v3.5.0 that adds Gmail notification capabilities to this app.
Congrats on the new release with Gmail added.
Hi, it appears that all SMTP sources I have (cox.net, live.com) need encryption (TLS?), any suggestions on that "intermediary" service I could use - Free is best.
I'd read the thread, but it works perfectly.
Something about HPM. Perhaps one day.
If you can't use Sendmail, then as posted just above, @ritchierich's integration supports notifications via Gmail. Also works very well.
Thanks. I'll try again, but I thought I tried all possible settings/ports/options. I probably got something wrong for my particular setup..
This is the log when it expires after the three retries.
Is there a way to change the Subject in the message that you set in the device so that I could use the 1 SendMail device for many notices?
I could not find a way in webCore or RM
The system notification call has no option for that. The only thing i can think of is a custom attribute you could set in a rule before sending the notification. But this would only work in std rule machine as other methods would not be able to do it. Not sure of the benefits.
In the other app that lets you send email (via Gmail), you can set a per-message Subject: by prefixing the message with "Subject:" and ending the subject with a comma.
E.g., "Subject: this is the subject,This is the body"
(@kahn-hubitat if you implement something, I'd suggest you make it compatible with that)
Correct. @kahn-hubitat I have an if statement in my code that looks for this condition:
if (message.startsWith("Subject:") && message.indexOf(",") > -1) {
def messageSplit = message.split(",")
subject = messageSplit[0].replace("Subject:", "")
message = messageSplit[1].trim()
Maybe you can do something similar.
Good idea i will look at implementing that.
Just in case you want to see the entire code its in the sendMessage function starting on line 1147:
Basically the subject gets passed into this function which defaults to the setting value on the child notification device and this code will overwrite it if the subject keyword is included in the message.
I am going to generalize that concept. But with a specific order caveat.
To: first
Cc: 2nd
Subject: third
If you put them in that order i think i could implement the capability to change all of them.
new version 4.9
- v 4.9 1/2023
- new changes to be able to modify/replace the From, to , subject or add a cc header
- the syntax is rh-Header: value,
- for instance to replace the subject form the hardcoded subject in your configuration would be: rh-Subject: New Subject, Remainder of the message
- There must be a comma after each replacment header directive.
- same for to rh-To:, From is rh-From,
- to add a CC header, it is rh-CC: email@email.com etc.
- Notes: if you had a list of multiple to addresses in the configuration panel only one can be in the new replacment header so that would override the entire list.
- other notes, order is important if you want to replace all headers (hence the rh-headername) you need to put them in this order:
- rh-From, rh-T0, rh-Subject, rh-CC .
- You dont need them all, but if any are there they must be in that order as that is the order they are processed.
- Otherwise they will be left in as part of your actual message.
let me know if you find any issues.
here is the bulk of the code change if you are interested.
Summary
// note order is important here from, to, subject,cc
if (state.debug) log.debug "before check for header replacment, subject = $emlSubject, body = $emlBody, from = $From, To = $To"
if (emlBody.startsWith("rh-From:") && emlBody.indexOf(",") > -1)
def io = emlBody.indexOf(",")
def len = emlBody.length()
if (state.debug) log.debug "found replace header for From! index = $io, len = $len"
def newFrom = emlBody.substring(0,io)
def messageSplit = emlBody.substring(io+1,len)
From = newFrom.replace("rh-From: ", "").replace("rh-From:", "")
emlBody = messageSplit.trim()
if (emlBody.startsWith("rh-To:") && emlBody.indexOf(",") > -1)
if (state.debug) log.debug "found replace header for To! index = $io, len = $len"
def newTo = emlBody.substring(0,io)
To = newTo.replace("rh-To: ", "").replace("rh-To:", "")
toReplaced = true
if (emlBody.startsWith("rh-Subject:") && emlBody.indexOf(",") > -1)
if (state.debug) log.debug "found replace header for Subject!"
def newSubject = emlBody.substring(0,io)
emlSubject = newSubject.replace("rh-Subject: ", "").replace("rh-Subject:", "")
if (emlBody.startsWith("rh-CC:") && emlBody.indexOf(",") > -1)
if (state.debug) log.debug "found replace header for CC!"
def newCC = emlBody.substring(0,io)
cc = newCC.replace("rh-CC: ", "")replace("rh-CC:", "")
ccFound = true
note: according to groovy specification trim() is supposed to trim white space from both the beginning and end of a string, but in hubitat it only seems to trim the end. Thus I had to work around it and that is why you see the double replace in the code.
Why the prefix?
for replace header rh so not do confuse becuase you can have From: or to: easily as the start of a message.
