Seeking help or guidance to resolve a C7 that becomes unresponsive, after 4-6 hours.
Symptoms::
Light stays green.
Can access via 8081 to reboot, which allowed it to run for about 6 hours; this seems to be reducing. As “the” hour approaches, the automations like turning lights on and off, or venting, become slower to respond or stop responding.
Background:
C7 has preformed perfect since before January 2024 without changes. On February 8th, new firmware was found and so the C7 was updated. Since then, things have not been good. Attempted several soft resets and restores from backups, also attempted restoring to previous firmware, this did not resolve things. Did network reset just in case.
With the help of a friend, who I am grateful, many things were tried: tracking memory and CPU usage every 5 minutes, attempting to reboot if CPU load went above 50% for 5 minutes, disabling the hub mesh to the C8, disabling larger apps (ecoBee suite, Alarm Panel for DSC), Airthings, webcore) The results were the same - reboot needed in 4-6 hours.
Summary of actions since Feb 8th:
Hub Information Driver v3 is installed, to track memory, cpu usage
Have soft reset and restored, a few times now.
Have downgrade back to 2.3.6.146 without soft reset and restore
Network reset.
Yes - can connect and shut down from 8081
Yes - can ping
Platform Version was: 2.3.6.146, now restored to 2.3.8.119
Hardware Version: C-7
Connection is ethernet - static IP assigned by mac address.
Power via supplied power block and cable
Ethernet cable connects to the same switch as everything else in home.
No firewalls, proxies or such between C7 and LAN and home devices.
Jumbo frames are not installed
Devices:
3 Zigbee devices shared from hub mesh with a C8
4 Matter devices shared from hub mesh with a C8
15 zwave devices
15 Lutron (Zigbee)
13 Meross (wifi) - started disabling as part of debugging
Had 4 Wemo (wifi) - now all removed as per of debugging (was always heavy and wanted to remove anyway)
1 EcoBee thermostat - 3 sensors - via Ecobee Suite Manager
12 DSC security via Hubitat Alarm App
3 Air Things device - via the Air Things Cloud
