aaiyar
April 27, 2022, 2:58pm
2
You can see repeating devices that are connected directly to the hub using the endpoint:
http://your.hubitat.ip/hub/zigbee/getChildAndRouteInfo
Every device under "Neighbor Table Entry" is a repeater connected directly to the hub. That table will not contain repeaters connected to the hub via another repeater.
Or, you can get an xbee3 and map out your zigbee network.
Since Xbee devices were taking the Xiaomi devices - are they pairing / staying connected for you? thread off track and info is scattered between here and the SmartThings forum.
I figured I would create a thread for everything Xbee related.
You can display Xbee zigbee network scans as a graph like this
[Xbee%20graph]
or a table like this
[Xbee%20table]
These are great little devices to use as routers to extend your network and for mapping out your zigbee network.
They have made my Xiaomi…
