Sorry dude, maybe the hide details function introduced extra characters? I just saved the driver file again on my C4 and C7 without error. I'll hate to do it, but posting the entire thing without hide details engaged
- Peanut Plug
- Copyright 2020 pakmanw@sbcglobal.net
- Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
- in compliance with the License. You may obtain a copy of the License at:
http://www.apache.org/licenses/LICENSE-2.0 - Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
- on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
- for the specific language governing permissions and limitations under the License.
- Peanut Plug
- Author: pakmanw@sbcglobal.net
- Change Log
- 2017-09-17 - v01.01 Created
- 2018-03-01 - v01.02 fix power accuracy issue
- 2018-12-23 - v01.03 merging jamesham change to get the calibrated attr from peanut plug,
add support for new smartthings app - 2019-01-17 - v01.04 merging jamesham retain state code
- 2019-09-27 - v01.05 update fingerprint from transman
- 2019-09-30 - v01.06 new interface, add active power settings
- 2019-10-01 - v01.07 add cost per kwh
- 2019-10-02 - v01.08 add reset time
- 2019-10-03 - v01.09 two decimal points for values
- 2020-02-23 - v01.10 fix energy value not update issues
- 2020-03-31 - v01.11 fix dickmal place display problem in some devices
import hubitat.zigbee.zcl.DataType
metadata {
definition (name: "Peanut Plug", namespace: "pakmanwg", author: "pakmanw@sbcglobal.net", ocfDeviceType: "oic.d.switch",
vid: "generic-switch-power-energy") {
capability "Energy Meter"
capability "Actuator"
capability "Switch"
capability "Power Meter"
capability "Polling"
capability "Refresh"
capability "Configuration"
capability "Sensor"
capability "Light"
capability "Health Check"
capability "Voltage Measurement"
attribute "current", "number"
attribute "switchStatus", "string"
command "reset"
fingerprint profileId: "0104", inClusters: "0000, 0001, 0003, 0004, 0005, 0006, 0B04, 0B05",
outClusters: "0000, 0001, 0003, 0004, 0005, 0006, 0019, 0B04, 0B05",
manufacturer: "Securifi Ltd."
// tile definitions
tiles(scale: 2) {
multiAttributeTile(name:"switch", type: "generic", width: 6, height: 4, canChangeIcon: true) {
tileAttribute ("device.switch", key: "PRIMARY_CONTROL") {
attributeState "on", label: '${name}', action: "switch.off", icon: "st.switches.switch.on", backgroundColor: "#00a0dc"
attributeState "off", label: '${name}', action: "switch.on", icon: "st.switches.switch.off", backgroundColor: "#ffffff"
tileAttribute ("device.switchStatus", key: "SECONDARY_CONTROL") {
attributeState "switchStatus", label:'${currentValue}'
standardTile("refresh", "device.refresh", width: 2, height: 2) {
state "refresh", label:'Refresh', action: "refresh", icon:"st.secondary.refresh-icon"
standardTile("reset", "device.reset", width: 2, height: 2) {
state "reset", label:'Reset', action: "reset", icon:"st.secondary.refresh-icon"
valueTile("power", "device.power", width: 2, height: 2) {
state "default", label:'${currentValue} W', backgroundColor: "#cccccc"
valueTile("energy", "device.energy", width: 2, height: 2) {
state "default", label:'${currentValue} kWh', backgroundColor: "#cccccc"
valueTile("voltage", "device.voltage", width: 2, height: 2) {
state "default", label:'${currentValue} V', backgroundColor: "#cccccc"
valueTile("current", "device.current", width: 2, height: 2) {
state "default", label:'${currentValue} A', backgroundColor: "#cccccc"
valueTile("history", "device.history", decoration:"flat", width: 6, height: 3) {
state "history", label:'${currentValue}'
main(["switch"])
details(["switch", "power", "energy", "refresh", "voltage", "current", "reset"])
preferences {
input name: "retainState", type: "bool", title: "Retain State?", description: "Retain state on power loss?", required: false, displayDuringSetup: false,
defaultValue: true
// configParams?.each {
// getOptionsInput(it)
input "energyPrice", "number", title: "$/kWh Cost:", description: "Electric Cost per Kwh in cent", range: "0..", defaultValue: 15
input "inactivePower", "decimal", title: "Reporting inactive when power is less than or equal to:", range: "0..", defaultValue: 0
// ["Power", "Energy", "Voltage", "Current"].each {
// getBoolInput("display${it}", "Display ${it} Activity", true)
private getOptionsInput(param) {
if (param.prefName) {
input "${param.prefName}", "enum",
title: "${param.name}:",
defaultValue: "${param.val}",
required: false,
displayDuringSetup: true,
options: param.options?.collect { name, val -> name }
private getBoolInput(name, title, defaultVal) {
input "${name}", "bool",
title: "${title}?",
defaultValue: defaultVal,
required: false
def installed() {
reset()
configure()
refresh()
def off() {
zigbee.off()
def on() {
zigbee.on()
def refresh() {
Integer reportIntervalMinutes = 5
setRetainState() +
zigbee.onOffRefresh() +
zigbee.simpleMeteringPowerRefresh() +
zigbee.electricMeasurementPowerRefresh() +
zigbee.onOffConfig(1, 600) +
zigbee.simpleMeteringPowerConfig(1, 600) +
zigbee.electricMeasurementPowerConfig(1, 600) +
voltageMeasurementRefresh() +
voltageMeasurementConfig(reportIntervalMinutes * 60, 600) +
currentMeasurementRefresh() +
currentMeasurementConfig(reportIntervalMinutes * 60, 600) +
zigbee.readAttribute(zigbee.ELECTRICAL_MEASUREMENT_CLUSTER, 0x0600) +
zigbee.readAttribute(zigbee.ELECTRICAL_MEASUREMENT_CLUSTER, 0x0601) +
zigbee.readAttribute(zigbee.ELECTRICAL_MEASUREMENT_CLUSTER, 0x0602) +
zigbee.readAttribute(zigbee.ELECTRICAL_MEASUREMENT_CLUSTER, 0x0603) +
zigbee.readAttribute(zigbee.ELECTRICAL_MEASUREMENT_CLUSTER, 0x0604) +
zigbee.readAttribute(zigbee.ELECTRICAL_MEASUREMENT_CLUSTER, 0x0605)
def currentMeasurementConfig(minReportTime=1, maxReportTime=600, reportableChange=0x0030) {
zigbee.configureReporting(zigbee.ELECTRICAL_MEASUREMENT_CLUSTER, 0x0508, DataType.UINT16, minReportTime, maxReportTime, reportableChange)
def currentMeasurementRefresh() {
zigbee.readAttribute(zigbee.ELECTRICAL_MEASUREMENT_CLUSTER, 0x0508);
def voltageMeasurementConfig(minReportTime=1, maxReportTime=600, reportableChange=0x0018) {
zigbee.configureReporting(zigbee.ELECTRICAL_MEASUREMENT_CLUSTER, 0x0505, DataType.UINT16, minReportTime, maxReportTime, reportableChange)
def voltageMeasurementRefresh() {
zigbee.readAttribute(zigbee.ELECTRICAL_MEASUREMENT_CLUSTER, 0x0505);
def getCurrentMultiplier() {
if (state.currentMultiplier && state.currentDivisor) {
return (state.currentMultiplier / state.currentDivisor)
} else {
return 0.001831
def getVoltageMultiplier() {
if (state.voltageMultiplier && state.voltageDivisor) {
return (state.voltageMultiplier / state.voltageDivisor)
} else {
return 0.0045777
def getPowerMultiplier() {
if (state.powerMultiplier && state.powerDivisor) {
return (state.powerMultiplier / state.powerDivisor)
} else {
return 0.277
def configure() {
log.debug "in configure()"
return configureHealthCheck() + setRetainState()
def configureHealthCheck() {
Integer hcIntervalMinutes = 12
sendEvent(name: "checkInterval", value: hcIntervalMinutes * 60, displayed: false, data: [protocol: "zigbee", hubHardwareId: device.hub.hardwareID])
return refresh()
def updated() {
log.debug "in updated()"
// updated() doesn't have it's return value processed as hub commands, so we have to send them explicitly
def cmds = configureHealthCheck() + setRetainState()
cmds.each{ sendHubCommand(new hubitat.device.HubAction(it)) }
def ping() {
return zigbee.onOffRefresh()
def setRetainState() {
log.debug "Setting Retain State: $retainState"
if (retainState == null || retainState) {
if (retainState == null) {
log.warn "retainState is null, defaulting to 'true' behavior"
return zigbee.writeAttribute(0x0003, 0x0000, DataType.UINT16, 0x0000)
} else {
return zigbee.writeAttribute(0x0003, 0x0000, DataType.UINT16, 0x1111)
def reset() {
state.energyValue = 0.0
state.powerValue = 0.0
state.voltage = 0.0
state.current = 0.0
state.costValue = 0.0
state.time = now()
sendEvent(name: "energy", value: (String.format("%.2f", state.energyValue)))
sendEvent(name: "cost", value: (String.format("%.2f", state.costValue)))
state.resetTime = new Date().format('MM/dd/yy hh:mm a', location.timeZone)
def refreshHistory() {
def history = ""
def items = [:]
items["energyDuration"] = "Energy - Duration"
items["energyCost"] = "Energy - Cost"
["power", "voltage", "current"].each {
items["${it}Low"] = "${it.capitalize()} - Low"
items["${it}High"] = "${it.capitalize()} - High"
items.each { attrName, caption ->
def attr = device.currentState("${attrName}")
def val = attr?.value ?: ""
def unit = attr?.unit ?: ""
history += "${caption}: ${val} ${unit}\n"
sendEvent(createEventMap("history", history, false))
// Configuration Parameters
private getConfigParams() {
return [
powerValueChangeParam,
powerPercentageChangeParam,
powerReportIntervalParam,
energyReportIntervalParam,
voltageReportIntervalParam,
electricityReportIntervalParam
private getPowerValueChangeParam() {
return createConfigParamMap(151, "Power Report Value Change", 2, getPowerValueOptions(), "powerValueChange")
private getPowerPercentageChangeParam() {
return createConfigParamMap(152, "Power Report Percentage Change", 1, getPercentageOptions(10, "No Reports"), "powerPercentageChange")
private getPowerReportIntervalParam() {
return createConfigParamMap(171, "Power Reporting Interval", 4, getIntervalOptions(30, "No Reports"), "powerReportingInterval")
private getEnergyReportIntervalParam() {
return createConfigParamMap(172, "Energy Reporting Interval", 4, getIntervalOptions(300, "No Reports"), "energyReportingInterval")
private getVoltageReportIntervalParam() {
return createConfigParamMap(173, "Voltage Reporting Interval", 4, getIntervalOptions(0, "No Reports"), "voltageReportingInterval")
private getElectricityReportIntervalParam() {
return createConfigParamMap(174, "Electrical Current Reporting Interval", 4, getIntervalOptions(0, "No Reports"), "electricityReportingInterval")
private createConfigParamMap(num, name, size, options, prefName, val=null) {
if (val == null) {
val = (settings?."${prefName}" ?: findDefaultOptionName(options))
return [
num: num,
options: options,
prefName: prefName,
val: val
// Settings
private getEnergyPriceSetting() {
return safeToDec(settings?.energyPrice, 0.12)
private getInactivePowerSetting() {
return safeToDec(settings?.inactivePower, 0)
private getDebugOutputSetting() {
return settings?.debugOutput != false
private getMinimumReportingInterval() {
def minVal = (60 * 60 * 24 * 7)
[powerReportIntervalParam, energyReportIntervalParam, voltageReportIntervalParam, electricityReportIntervalParam].each {
def val = convertOptionSettingToInt(it.options, it.val)
if (val && val < minVal) {
minVal = val
return minVal
private getIntervalOptions(defaultVal=null, zeroName=null) {
def options = [:]
if (zeroName) {
options["${zeroName}"] = 0
options << getIntervalOptionsRange("Second", 1, [5,10,15,30,45])
options << getIntervalOptionsRange("Minute", 60, [1,2,3,4,5,10,15,30,45])
options << getIntervalOptionsRange("Hour", (60 * 60), [1,2,3,6,9,12,18])
options << getIntervalOptionsRange("Day", (60 * 60 * 24), [1,3,5])
options << getIntervalOptionsRange("Week", (60 * 60 * 24 * 7), [1,2])
return setDefaultOption(options, defaultVal)
private getIntervalOptionsRange(name, multiplier, range) {
def options = [:]
range?.each {
options["${it} ${name}${it == 1 ? '' : 's'}"] = (it * multiplier)
return options
private getPowerValueOptions() {
def options = [:]
[0,1,2,3,4,5,10,25,50,75,100,150,200,250,300,400,500,750,1000,1250,1500,1750,2000,2500,3000,3500,4000,4500,5000,6000,7000,8000,9000,10000,12500,15000].each {
if (it == 0) {
options["No Reports"] = it
else {
options["${it} Watts"] = it
return setDefaultOption(options, 50)
private getPercentageOptions(defaultVal=null, zeroName=null) {
def options = [:]
if (zeroName) {
for (int i = 1; i <= 5; i += 1) {
options["${i}%"] = i
for (int i = 10; i <= 100; i += 5) {
private convertOptionSettingToInt(options, settingVal) {
return safeToInt(options?.find { name, val -> "${settingVal}" == name }?.value, 0)
private setDefaultOption(options, defaultVal) {
def name = options.find { key, val -> val == defaultVal }?.key
if (name != null) {
return changeOptionName(options, defaultVal, "${name}${defaultOptionSuffix}")
else {
return options
private changeOptionName(options, optionVal, newName) {
def result = [:]
options?.each { name, val ->
if (val == optionVal) {
name = "${newName}"
result["${name}"] = val
return result
private findDefaultOptionName(options) {
def option = options?.find { name, val ->
name?.contains("${defaultOptionSuffix}")
return option?.key ?: ""
private getDefaultOptionSuffix() {
return " (Default)"
private createEventMap(name, value, displayed=null, desc=null, unit=null) {
desc = desc ?: "${name} is ${value}"
def eventMap = [
value: value,
displayed: (displayed == null ? ("${getAttrVal(name)}" != "${value}") : displayed)
if (unit) {
eventMap.unit = unit
desc = "${desc} ${unit}"
if (desc && eventMap.displayed) {
logDebug desc
eventMap.descriptionText = "${device.displayName} - ${desc}"
else {
logTrace "Creating Event: ${eventMap}"
return eventMap
private getAttrVal(attrName) {
try {
return device?.currentValue("${attrName}")
catch (ex) {
logTrace "$ex"
return null
private safeToInt(val, defaultVal=0) {
return "${val}"?.isInteger() ? "${val}".toInteger() : defaultVal
private safeToDec(val, defaultVal=0) {
return "${val}"?.isBigDecimal() ? "${val}".toBigDecimal() : defaultVal
private roundTwoPlaces(val) {
return Math.round(safeToDec(val) * 100) / 100
private convertToLocalTimeString(dt) {
def timeZoneId = location?.timeZone?.ID
if (timeZoneId) {
return dt.format("MM/dd/yyyy hh:mm:ss a", TimeZone.getTimeZone(timeZoneId))
else {
return "$dt"
private isDuplicateCommand(lastExecuted, allowedMil) {
!lastExecuted ? false : (lastExecuted + allowedMil > new Date().time)
// log.debug "description is $description"
def event = zigbee.getEvent(description)
if (event) {
if (event.name == "power") {
def powerValue = (event.value as Integer) * getPowerMultiplier()
sendEvent(name: "power", value: (String.format("%.2f", powerValue)))
def time = (now() - state.time) / 3600000 / 1000
state.time = now()
// log.debug "powerValues is $state.powerValue"
state.energyValue = state.energyValue + (time * powerValue)
state.powerValue = powerValue
// log.debug "energyValue is $state.energyValue"
def localCostPerKwh = 15
if (energyPrice) {
localCostPerKwh = energyPrice as Integer
state.costValue = roundTwoPlaces(state.energyValue * localCostPerKwh / 100)
if (inactivePowerSetting == null) {
inactivePowerSetting = 0
if (state.resetTime == null) {
def costStr = (String.format("%.2f", state.costValue))
def switchStatusS = (powerValue > inactivePowerSetting) ? "Active | Cost $$state.costValue since $state.resetTime" :
"Inactive | Cost $$costStr since $state.resetTime"
// log.debug "$switchStatusS"
sendEvent(name: "switchStatus", value: switchStatusS, displayed: false)
// refreshHistory
} else {
sendEvent(event)
} else if (description?.startsWith("read attr -")) {
def descMap = zigbee.parseDescriptionAsMap(description)
// log.debug "Desc Map: $descMap"
if (descMap.clusterInt == zigbee.ELECTRICAL_MEASUREMENT_CLUSTER) {
def intVal = Integer.parseInt(descMap.value,16)
if (descMap.attrInt == 0x0600) {
// log.debug "ACVoltageMultiplier $intVal"
state.voltageMultiplier = intVal
} else if (descMap.attrInt == 0x0601) {
// log.debug "ACVoltageDivisor $intVal"
state.voltageDivisor = intVal
} else if (descMap.attrInt == 0x0602) {
// log.debug "ACCurrentMultiplier $intVal"
state.currentMultiplier = intVal
} else if (descMap.attrInt == 0x0603) {
// log.debug "ACCurrentDivisor $intVal"
state.currentDivisor = intVal
} else if (descMap.attrInt == 0x0604) {
// log.debug "ACPowerMultiplier $intVal"
state.powerMultiplier = intVal
} else if (descMap.attrInt == 0x0605) {
// log.debug "ACPowerDivisor $intVal"
state.powerDivisor = intVal
} else if (descMap.attrInt == 0x0505) {
def voltageValue = roundTwoPlaces(intVal * getVoltageMultiplier())
// log.debug "Voltage ${voltageValue}"
state.voltage = $voltageValue
sendEvent(name: "voltage", value: (String.format("%.2f", voltageValue)))
} else if (descMap.attrInt == 0x0508) {
def currentValue = roundTwoPlaces(intVal * getCurrentMultiplier())
// log.debug "Current ${currentValue}"
state.current = $currentValue
sendEvent(name: "current", value: (String.format("%.2f", currentValue)))
} else {
log.warn "Not an electrical measurement"
} else {
log.warn "DID NOT PARSE MESSAGE for description : $description"
log.debug zigbee.parseDescriptionAsMap(description)
