Schlage Locks - It's the built in driver, stupid
@jdmm72 - you want to chime in here? @user5027 is using the resurrected driver that you have claimed fixes all issues with these Schlage locks - so I figure you’re in the best position to figure out why their lock is not working even with the driver you’ve espoused on multiple threads.
No, he's not using my driver, or a driver I tried, he's using
"'Z-Wave Schlage Touchscreen Lock' by 'garyd9' . Code looks like it's a port from SmartThings back in 2014."
The drivers I initially used were hansanderson and edalquist.
And this is the SAME ISSUE that I initially reported. You can pair it, it works UNTIL the next reboot of the hub, then it will only report that status, but not act in any commands. Then you can exclude it, pair it again, and it again will work until the hub is rebooted... Rinse and repeat.
I've pretty much completely rewritten my version though, and it's working fine with my locks, even through reboots. I'm not sure I have pushed it to my GitHub repo yet though.
