I use Vera. I’m thinking of getting Hubitat. Vera has Scenes that automate devices turning on and off.
Where in Hubitat can you do that? i could not find it in the documentation.
Have a whole category for you Groups and Scenes - Hubitat
Thanks! Does Hubitat allow me to turn on devices an hour before dusk and turn then off a half an hour before daylight?
Also turn a pump on every 30 minutes for 1 minute?
Thanks in advance
Yes absolutely. Once you create the scene, Hubitat creates a virtual scene activator that you can use in any automation. For turning on/off a certain time like before dusk, I would suggest using Basic Rules....Basic Rules | Hubitat Documentation
Both of those things are totally possible.
Hubitat has numerous different native (i.e. built/maintained by Hubitat staff) applications to manage automations -- that can be understandably confusing at first...
For instance, for rule-building, options include "Basic Rules", "Simple Automation Rules", "Visual Rule Builder", Rule Machine" and WebCore. Then there are more specialized options for dealing with specific things -- like "Basic Button Controller", "Button Controller" and "Room Lighting".
In some cases, these options may be older tools that aren't deprecated, but also aren't being actively maintained since they were replaced with a newer tool. An example of this would be that "Simple Automation Rules" has been superceded by "Basic Rules".
The "Group and Scenes" app mentioned previously is another example of that -- it's been superceded by "Room Lighting".
These older tools are still available because it would be hard for many exisitng users to transfer to a newer tool if they suddenly disappeared,
If staff ever decides to fully deprecate any of these older tools, I'm sure they'll give a healthy head's-up about it, but I myself would not use them if I were brand new to the platform... If I was just starting out, I'd plan to avoid the older tools. But that's just my $0.02 (and worth that much!)
The Hubitat Documentation is very good, and can be a helpful research resource.
The Search tool within the community here is also a powerful resource (magnifying glass in upper right corner of this window).
This post here would be helpful with respect to nuts-&-bolts transition planning:
I am a longtime Vera user, over 10 years. I switched to Hubitat last March and have been very happy with my decision.
Anyway I had given up on Vera and Ezlo due to he slow progress on the platform. Ezlo is very buggy, changes are glacial, and many features are only partially implemented as if they were a demo for a proof of concept meeting. Not hardened as needed for an important home control appliance. They do a lot of apologizing on the Ezlo forums but not enough action behind it.
As @hydro311 states this is totally possible and there are several ways to go about this. Rather than go into the details for this application, I suggest starting with automating your lights. Once you are comfortable with that, you can post back here in the forum on how to turn your pump on every 30 minutes and we will help you.
@CuriousB how do we message each other? I purchased this and then read your post. i need to be able to set up scenes and turn them on and off with an app like we were able to in Vera.
I run scenes via the gui by creating a virtual switch in Hubitat and naming it something similar to the scene name. Then I put that switch as a trigger on the scene I want to manually control. In the scene action section I switch off (with delay) the same virtual switch so it runs only once. I put a delay of 1-2 seconds on the switch turn off so there is more of a tactile look on the gui of the switch going on so it doesn;t immediately turn off making you think something is amiss.
Easy to do and works well.
You will learn in Hubitat world there are two camps. One say having a dashboard and gui to control is normal. The other says you don't need a dashboard or gui because all scenes should be triggered without manual intervention (motion, time of day, event of some sort) and that "proper" automation is well thought through and doesn't need dashboards. As with anything the truth rests in the middle somewhere and is different for everyone....
