Hi, I set up a simple rule and can't seem to figure out why it is not behaving as expected. I have a Zigbee contact sensor and a Schlage zigbee lock on my front door. Both work perfectly. I set up a rule to lock the door after a 30 second delay only if the contact sensor is closed and the door is unlocked. However the behavior I am seeing is the door locks after 30 seconds whether the contact sensor shows open or closed. Obviously I don't want the door to locked when it is still ajar. Here is the rule I set up. Anybody see the problem in this logic?
Thanks!
