Rule machine bug
Yes we do wonder since no one in this thread is a Hubitat developer (Some are community developers but they don't work for hubitat or have access to the Hubitat code). Both @bravenel and general support have been notified. All you can do is wait for a response. In the mean time people are trying to get to the bottom of the "bug" by asking questions and seeing if they can replicat it. Offering a terse attitude in return helps nobody.
Yup, support team notified.
Best of luck to the OP.
Trying to be helpful here and explaining that while you have the rule open, changing the state of something that alters the Reqiured Expression true/false value is not recognized until you ā€œtickleā€ the rule by updating it.
Again you have NOT shown evidence (logs, etc.) that indicates that this is a BUG.
Likely that’s why you are feeling ignored by HE support.
I tried, I’m tired, and I’m done here.
Hopefully not. But there is an "Update all rules" button on the parent "Rule Machine" app's config page you can use to... update all rules, if you want to.
Impossible to tell from the evidence you have presented so far. Not clear how you got the rule's required expression evaluation to be out of sync with the switch state; somehow the rule must have missed an on-to-off transition event. Since the switch is being mirrored via Hub Mesh, could be that the event happened on the hub where the device is paired while the hub that hosts the rule was rebooting, just to give one example that comes to mind.
Update reinitializes the rule so it re-evaluated the state of the required expression even though there was no switch event to trigger that evaluation.
Could also be there was a problem with the rule's subscriptions, which Update would have fixed, too, but if that was the case, flipping the switch on and back off would not have restored its state. You can check the rule's event subscriptions to make sure they are correct by clicking the circled-i icon.
@bravenel, the author of the Rule Machine app, has not posted on the forum for many months. I too reported some issues that have yet to be acknowledged by HE staff. My guess is that they are busy fixing other things that make a bigger difference to their users (and bottom line) than bugs for which workarounds exist. Still frustrating, I get it.
2 posts were split to a new topic: Diversion from "Rule machine bug"
Hub logs showing evidence of a bug are best, but there's nothing you can do about it after the fact. That would require turning on Event and Trigger logging on the rule(s) and description logging on the device. You can still do that if you think the problem will happen again.
Something you can still do (soon) after the fact is check the focus switch's device events (from the device details page on the hub where the rule runs) and double-check that the event that should have triggered the rule is there.
The point is: more information is needed in order to reproduce a bug and fix it.
I already acknowledged that you shouldn't have to, but you asked a direct question about the difference between Update and flipping the switch, and I provided one, that's all.
In that case, I can't help you, sorry.
If required expressions were broken in such a way that switch events were randomly missed, you can imagine there would be more than one user reporting that. So if what you are reporting is truly a bug - whether it is in Rule Machine, Hub Mesh, device driver, device itself - it is probably subtle and requires more information.
My advice:
  • Use the "Update all rules" button in the Rule Machine parent app to make sure all rule subscriptions (required expressions and triggers) are clean
  • Turn on logging on the rules you had issues with and the device(s) involved
  • Wait and see if the issue happens again
Good luck.
if i was able to reproduce the bug I would, this rules have been working for months as I said so is a random bug that I have no idea what happened and 3 rules all 3 having the same condition failed .
I already checked the logs and I said, there's nothing there, expression turned false as it should when focus switch was ON, then when focus was turned off the expression falsely remained false, no other logs shown
Given the randomness nature of the bug I don't have any expectations to be fixed, I can just hope it won't happen again, it wasn't a big deal but obviously annoying to come downstairs after 3h and still finding your lights on
A post was merged into an existing topic: Diversion from "Rule machine bug"
