syepes
March 1, 2020, 7:39pm
1
Hello,
I am trying to build a condition that only executes the action if the device attribute is true (Boolean), I have been trying to make this work for the past hour but either I am missing sometime or this is not supported.
Questions:
Is this supported?
Is this a driver attribute definition issue?
UI Issue:
This is the driver I am using:
capability "Sensor"
capability "Refresh"
capability "Configuration"
capability "Initialize"
command "clearState"
attribute "rainMeter", "number"
attribute "rainRate", "number"
attribute "rainTotal", "number"
attribute "rain", "enum", ["true","false"]
attribute "rainHeavy", "enum", ["true","false"]
fingerprint mfr:"0154", prod:"0004"
fingerprint deviceId: "17", inClusters: "0x5E, 0x31, 0x70, 0x85, 0x80, 0x84, 0x32, 0x7A, 0x5A, 0x59, 0x73, 0x86, 0x72"
preferences {
section { // General
input name: "logLevel", title: "Log Level", type: "enum", options: LOG_LEVELS, defaultValue: DEFAULT_LOG_LEVEL, required: false
input name: "logDescText", title: "Log Description Text", type: "bool", defaultValue: false, required: false
codahq
March 1, 2020, 8:41pm
2
Known limitation:
What device is this? How was the attribute "chime" defined? Chances are it was incorrectly defined as something that doesn't exist or maybe boolean isn't working. I couldn't find an example of it anywhere on a google 'site:github.com "hubitat" "bool" "attribute"' search.
I most often see attributes defined as type "string", "enum", or "number" but "bool" should work according to this.
https://docs.hubitat.com/index.php?title=Attribute_Object
You might want to use 1 or 0 or "true" or "false" or "some thing" and "something else" for now.
syepes
March 1, 2020, 10:37pm
3
@codahq
Thanks for the pointer!
Fix the issue by converting the driver to an enum
capability "Sensor"
preferences {
system
Closed
September 19, 2022, 7:11pm
4
