@bravenel@gopher.ny Wonder if you can take a look at this strange behavior. When running a rule on Rule Machine 5.0 and you select two thermostats as an action to run almost every time one of the rules for one thermostat wont run properly... The combination like this in Rule Machine (except set to cool when I performed the test)
Yes they are Z-Wave. Just so I understand correctly, "Action:" is command sent? In the last screenshot above, these are two separate thermostats and the first command (Mode:heat), the living room takes the command, the garage doesn't it appears. Manually using it it never misses a beat which strikes me odd. As you can see I have put delays in to cover off the Z-Wave thermostat not being able to handle commands quick enough in further actions. Any suggestions to make it more reliable?
How bizarre, I added a 2 second delay for the mode changes and it works. That doesn't makes sense to me considering they are two completely separate devices controlling separate heaters. Why can't I send both the same time?
