Further experimentation - it's not using the auto-level. It turns on to the previous level - in this case it was 20%, which was what the Checking dimmed it to before turning off.
i put in some new code for optimizing switches processing. wondering if that is causing issues. from state for the app could you please share the rules value. should look something like this:
thanks. this is for the same room right? did you recently save the room? if yes try triggering the occupancy again then find rules from the same place and share the value please.
Version: 0.90.4
DONE: 10/3/2018
1) added color option to night lights.
2) tweaked the holiday lights twinkle a bit for HE.
3) optimized switches processing.
4) started adding sub-headers on HE.
@kilowatts please update to 0.90.4 before trying AL. after update turn on debug for the room from GENERAL SETTINGS then lets see what values are getting calculated in AL from the logs.
@hughlipham the switches should turn off right with this version. if you are going to try twinkle please try after updating to this version.
@jbeard night lights with color only for your better half.
I have moved across my Rooms Manager from ST to HE. One thing I cant seem to set - priority of rules within Hubitat. I have one light that is "signal" light for open doors. When garage door opens, I want that light to turn red.
Problem is that in HE, Rooms Manager overrides the command to turn the code red, and it turns back white, or off. In ST, it didnt (via webcore).
So far, I've only tried via Rules Machine to turn the signal light red. I've tried setting the room to locked when contact sensor opens AND locked overrides trigger devices for other states, but Rooms Manager took priority over Rules Machine, and the light turned didn't change color. Then I tried the above, with Locked NOT overriding other states, and the light did turn red, but within 10 seconds, Rooms Manager (I presume) turned the light white, before the contact sensor was shut.
What is the order of priority in HE? Any way to achieve this? Would Webcore take priority over Rules Machine and Rooms Manager. As I said, this was not an issue in ST. I've checked my Rooms Manager settings there.......
Edit: I seem to have got it working, but the room goes to vacant after locked. Is there a way to set it to whatever the status was before locked, or is there a better way to do this?
