I have a RL rule that has a button set for activation and for turning off. When I push it, RL turns the lights on and then immediately off again. Can see in the device events that the on command is sent followed by the off immediately after. Assuming this is a bug?
I'm seeing this as well. Had it on a motion sensor trigger this morning in addition to the button. So I'm not sure if it's something I'm doing or if it's something else.
BlockquoteI have a RL rule that has a button set for activation and for turning off. When I push it, RL turns the lights on and then immediately off again. Can see in the device events that the on command is sent followed by the off immediately after. Assuming this is a bug?
You have the same button defined to activate the light and to turn if off. Perhaps it's getting confused? I'm not sure what kind of device Button - Master Robe is. Does it have a second button or a double-tap or something that could be used for either on or off?
Go into the Means to Activate, select Button is pressed (like you had before), and deselect the button device. Then done out of that, and hit Update. It should be what you show now without actHandler in the list for buttonTable.
