See this:
Easiest solution is just to remove this and set it up correctly from scratch.
See this:
Too easy. It's a pretty basic RL rule, i'll just scrap it and recreate it when I get home.
Unrelated, I did notice that the Button Controller 5.1 seems to clear its button subscription when you clear all the actions as well still. The subscription is there but says button.null instead of button.1.
This occurs when you clear the existing actions to change them to something else.
Interesting... I will look into that.
I'm not seeing this. First of all, Button Controller 5.1 does not have any event subscriptions, only the individual Button Rule 5.1 instances have subscriptions. If you create one, but don't give it any actions, it has an event subscription to the correct button. If you remove all of the actions from one, it still has its event subscription as well, and it is correct.
So I don't know how you could get "button.null" from a Button Rule, and you certainly can't get it from Button Controller.
If you can reproduce this, please list the exact steps to do so.
No prob. I'll go through it when I get home.
Thanks Bruce, recreating the RL rule worked for doing that toggle.
I tried the button controller again and it seemed to keep the event subscription fine, so this may be gone now, thanks for looking at it though.
