Yeah Harmony hubs are awesome for sure. I use one in my sons streaming building to turn on an AC unit before the stream to keep it cool in there, So I know they are useful. I just don't have enough devices to justify adding one in the living room. I have a roku TV which I can control through Hubitat or the Google hub and a soundbar that the TV controls directly. I just added a bond hub recently and I'm liking it so far but the wife was a little worked up over yet another hub deployment. You can't blame her I have Hubitat still have ST (Not for long) Hue hub and 24 port switch and my camera's DVR as well as bond now all in the living room. I keep most of my devices in the garage servers etc but needed some items in the house for performance of course. The camera DVR should be in the garage now but I don't have the heart to crawl around in the attic and rewire it all.
Yeah I agree they are good at some things but seem to leave other projects sitting high and dry. Just like my vehicle with there Sync option. Now ford has dropped them for blackberry I believe. I know I lost a lot of functionality when they did this like the send to sync funtion for GPS navigation.
What?! ![]()
Are they going to replace their engines with actual horses too? ![]()
lol anything is possible. I seen the blackberry interface though it is a real step up from Sync. I actually loved my blackberry though. As far as dependable service in this area it was one of the best. Kind of like the razer flip phone as far as making phone calls in this area those were the best phones to have. We live in a small town with limited technology and lot's of mountains!
lol! Razr phones. I had one..
@mik3 me too. As far as making and receiving calls it worked great!
Ok... I've seen this thread a few time in the past day... and it's just sad...
To implement the OPs request does NOT involve a websocket and should not involve an external server...
The referenced code builds and sends a special UDP packet to an Xbox at a specific address...
So in hubitat, you would need a small driver with a switch capability, and the code to collect the IP address and Xbox Live ID then build and sent the UDP packet...
* XBOX Power On Device Type
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Original Author: CybrMage
public static String version() { return "v0.0.2" }
metadata {
definition (name: "XBOX Power ON", namespace: "cybr", author: "CybrMage")
capability "Switch"
command "on"
preferences {
input name: "XboxIP", type: "text", title: "XBOX IP Address", defaultValue: "", required: true
input name: "XboxID", type: "text", title: "XBOX Live Device ID", defaultValue: "", required: true
input ("debug", "bool", title: "Enable debug logging", defaultValue: false)
def log_debug(logMsg) {
if (debug == true) { log.debug(logMsg) }
def installed()
log_debug("XBOX Power ON Driver - installed - ip: ${XboxIP} ID: ${XboxID}")
def initialize()
log_debug("XBOX Power ON Driver - initialize - ip: ${XboxIP} ID: ${XboxID}")
def updated()
log_debug("XBOX Power ON Driver - updated - ip: ${XboxIP} ID: ${XboxID}")
def on()
log_debug "Executing 'Power On'"
if ((XboxID == null) || (XboxID == "")) {
log_debug("XBOX Live ID not set")
return
def IDlen = XboxID.length()
def payloadLen = (XboxID.length() + 3)
def encID = hubitat.helper.HexUtils.byteArrayToHexString(XboxID.toUpperCase() as Byte[])
def UDPmessage = "00" + hubitat.helper.HexUtils.integerToHexString(IDlen,1) + encID + "00"
def UDPheader = "DD0200" + hubitat.helper.HexUtils.integerToHexString(payloadLen,1) + "0000"
def UDPdata = UDPheader + UDPmessage
sendUDP(UDPdata)
def off()
log_debug "'Power Off' not supported"
def sendUDP(String message)
// message should be a hex encoded string
if ((XboxIP == null) || (XboxIP == "")) {
log_debug("Xbox IP address not set")
return
log_debug("sendUDP: sending [${message}] to [${XboxIP}:5050]")
def myHubAction = new hubitat.device.HubAction(
message,
hubitat.device.Protocol.LAN,
type: hubitat.device.HubAction.Type.LAN_TYPE_UDPCLIENT,
destinationAddress: "${XboxIP}:5050",
encoding: hubitat.device.HubAction.Encoding.HEX_STRING,
ignoreResponse: true
sendHubCommand(myHubAction)
You would then create a virtual device using the driver, then enter the IP address and the Live ID, save the preferences, then use the "on" command to send the UDP packet.
Awesome thank you so much. I'm at work now but really excited to try this out this evening. @cybrmage did you write the code? This is exactly what I was looking for fingers crossed it works!
Got my answer thank you much (Original Author: CybrMage) this is great where do I go to support you man. You are the best brother!
This is great, thanks!
I had another thread bookmarked where this was being discussed, but nobody had written a solution yet - I will link them back to your solution.
One thing that might be helpful to add to your post or driver - you mentioned the "Live ID" and I wrongly assumed this was my Xbox Live ID name or email. What was needed was the "Xbox Live Device ID", which can be retrieved from Settings - System - Console Info on the Xbox itself.
I got this setup and configured. It is working although it seems a little buggy. Got the power on option to work 2 out of 5 tries and the off button never did work. This may be something with Xbox's solution or something though. Not sure if it has improved since I first tried years ago to boot it from my server so I could play remotely. I have a domain name and dynamic dns setup for remote access to some of my network resources. Anyone else have issues let me know. Not sure how much time I will have this evening but plan on digging into it more this weekend for sure.
Also wanted to mention make sure you power it off if it is already on before trying to use the virtual device. Mine was already on and I was not able to even get the power on to work initially prior to power it off. Could just be coincidence but I tried 20 times at least and nothing.
In the code they didnโt implement the off command. Not sure if the UDP request is 100% correct either.
AWWW ok no problem @aaron I'm just happy we have something to use. Just want to make sure we document any/all issues for others. I know I used this script or one like it years ago and seen some dependencies as well. Anyway I just want to make sure @cybrmage knows these are not complaints only trying to document and figure it out for others who come after us.
Oh did I mention how flipping awesome this is? I really need to learn to code and develop I just have such a hard time wrapping my head around it.
This is what I'm seeing in my logs this morning.
dev:5452019-08-31 07:44:18.821 am warnError occured with UDP message: SocketTimeoutException: Receive timed out
dev:5452019-08-31 07:44:15.805 am debug'Power Off' not supported
dev:5452019-08-31 07:44:15.037 am debug'Power Off' not supported
dev:5452019-08-31 07:44:13.301 am warnError occured with UDP message: SocketTimeoutException: Receive timed out
dev:5452019-08-31 07:44:08.804 am debugsendUDP: sending [DD020013000000104644303033363046364542343031394400] to [10.1.10.71:5050]
dev:5452019-08-31 07:44:08.799 am debugExecuting 'Power On'
dev:5452019-08-31 07:44:03.280 am debugsendUDP: sending [DD020013000000104644303033363046364542343031394400] to [10.1.10.71:5050]
So I did a lot more research surrounding turning on/off an Xbox.
Xbox turning on can be initiated from a UDP call to IP_Addy:5050.
Turning off an XBOX can only be initiated from the controller, Xbox button or from Xbox live. So there is no way to turn off an Xbox without developing connectivity to Xbox live and acquiring a temporary token.
Turn off can be performed with the smartglass API (the ip_Addy:5050 system)... But the smartglass API only supports two commands (Power On and Discovery) that are unencrypted. The encrypted commands require AES encryption, and therefore can not (at this time) be implemented on the hubitat.
You can do this in Hubitat. It just needs to send the off command through Xbox live verses direct. Hence my comment and research. I installed and tore apart the Python Smartglass code today. Without a valid token you cannot connect locally. BUT you could initiate a power off through Xbox live but again this requires a lot of programming. So nothing quick and dirty unfortunately.
You can't do encryption in Hubitat code (there's a couple of people requesting it here, but no official response) - it doesn't matter how much programming you do if you can't access the classes you need ![]()
I use Hubitat with a virtual contact that turns on or off Xbox.
Thatโs how Iโm doing it
@mik3 Can you share more info?
