%device% and %value% are now available in HSM and Rule Machine, in new release: Hub Update 1.1.3
Yes, I saw that in your release notes. Looking forward to trying it out.
Thank you!!
Looks like it wasn't added to HSM "custom apps" though?
No, next release....
I just tried this out in rule machine. So far works great! Thanks for this, its kind of a big deal!
I also noticed it looks like there is now a way to disable a rule without deleting it! Big improvements!
I don't see a new option...are you referring to the Switch to Disable Rule or the Private Boolean?...those were there before the latest update.
Yes, I was referring to the Switch to Disable Rule. Didn't notice it before.
Ah, it's always been there.
This has been added in the recent hot fix release: Hub Update 1.1.3 - #3 by bravenel
I finally got around to revising my notifications using the device and value parameters. This is exactly what I hoped for. Thank you!
Finally upgraded and tried this out--exactly what I was looking for! Now when a door opens, our British butler says "The front door opened". Thanks a bunch for implementing this!
I have a little issue when trying to send a notification from RM.
Once I've set up the Rule and saved it, it looks correct ....
But the sent message gets truncated and when I go into the Rule to check, it looks like this...
I deleted the Rule and recreated it but the issue persists. Anyone else noticed this ??
It's probably from you putting quotes in the message. Try taking those out.
Oh, that was it.
Working as expected now.
Cheers,
Nic
