thanks Braveel for jumping in!
got a weird one that I thought I solved but came back.
turned all lights on in the house (calling different RL: basement, main floor and 2n floor)
then wait 5-10 seconds and call the house off (named dodo)
everything goes off then lights to the second floor goes on.
starts with this one
CDM-Escalier-D was set to 10
and I feel/think that trigger lights in RL-3w-Escalier2e to also go on. but that RL is configured to go on and off "physical only" so not sure why they go on too.
those 3 have been excluded, factory defaulted, paired and the RL got re-created yesterday.
dev:1052022-10-07 02:49:54.243 PMinfogroupState someOn
app:2202022-10-07 02:49:54.235 PMinfoRL-Dodo not Active
dev:1232022-10-07 02:49:54.233 PMinfogroupState someOn
dev:1232022-10-07 02:49:54.209 PMinfoDodo indicator off
app:2222022-10-07 02:49:54.134 PMinfoRL-2e not Active
dev:1252022-10-07 02:49:54.131 PMinfogroupState someOn
dev:1252022-10-07 02:49:54.126 PMinfo2e etage indicator off
app:2202022-10-07 02:49:51.171 PMdebugEvent: RDC-Escalier-D3w switch on
dev:1032022-10-07 02:49:51.085 PMinfogroupState allOff
app:2212022-10-07 02:49:51.019 PMinfoRL-SousSol-on not Active
dev:1242022-10-07 02:49:51.016 PMinfogroupState allOff
dev:1242022-10-07 02:49:51.009 PMinfoSousSol-on indicator off
app:2162022-10-07 02:49:51.002 PMinfoActivating for All Modes
app:2162022-10-07 02:49:50.988 PMinfoActivation Event: 'RDC-Escalier-D3w' switch on
app:1972022-10-07 02:49:50.977 PMinfoRDC-On not Active
dev:982022-10-07 02:49:50.974 PMinfogroupState allOff
dev:982022-10-07 02:49:50.958 PMinfoRL-RDC-On indicator off
app:2202022-10-07 02:49:50.946 PMdebugEvent: RDC-Escalier-D3w level 99
dev:1152022-10-07 02:49:50.909 PMinfoRDC-Escalier-D3w was turned on
dev:1152022-10-07 02:49:50.907 PMinfoRDC-Escalier-D3w was set to 99
dev:1152022-10-07 02:49:50.904 PMdebugparse:zw device: 42, command: 2603, payload: 63 63 05 , isMulticast: false
app:2202022-10-07 02:49:50.437 PMdebugEvent: CDM-Escalier-D level 99
app:2162022-10-07 02:49:50.407 PMinfosetLevel: RDC-Escalier-D3w, level: 99
dev:1152022-10-07 02:49:50.396 PMdebugsetLevel(99, null)
app:2202022-10-07 02:49:50.383 PMdebugEvent: 2e-2e-D switch on
app:2162022-10-07 02:49:50.368 PMinfosetLevel: CDM-Escalier-D, level: 99
dev:1142022-10-07 02:49:50.346 PMinfoCDM-Escalier-D was turned on
dev:1142022-10-07 02:49:50.339 PMdebugsetLevel(99, null)
dev:1142022-10-07 02:49:50.329 PMinfoCDM-Escalier-D was set to 99
app:2162022-10-07 02:49:50.325 PMinfoActivating for All Modes
dev:1142022-10-07 02:49:50.325 PMdebugparse:zw device: 41, command: 2603, payload: 63 63 05 , isMulticast: false
app:2162022-10-07 02:49:50.321 PMinfoActivation Event: '2e-2e-D' switch on
app:2202022-10-07 02:49:50.312 PMdebugEvent: 2e-2e-D level 99
dev:1132022-10-07 02:49:50.284 PMinfo2e-2e-D was turned on
dev:1132022-10-07 02:49:50.282 PMinfo2e-2e-D was set to 99
dev:1132022-10-07 02:49:50.279 PMdebugparse:zw device: 40, command: 2603, payload: 63 63 05 , isMulticast: false
app:2162022-10-07 02:49:49.340 PMinfosetLevel: RDC-Escalier-D3w, level: 99
dev:1152022-10-07 02:49:49.328 PMdebugsetLevel(99, null)
app:2162022-10-07 02:49:49.300 PMinfosetLevel: CDM-Escalier-D, level: 99
app:2202022-10-07 02:49:49.292 PMdebugEvent: CDM-Escalier-D switch on
dev:1142022-10-07 02:49:49.288 PMdebugsetLevel(99, null)
app:2162022-10-07 02:49:49.279 PMinfosetLevel: 2e-2e-D, level: 99
dev:1132022-10-07 02:49:49.268 PMdebugsetLevel(99, null)
app:2162022-10-07 02:49:49.235 PMinfoActivating for All Modes
app:2162022-10-07 02:49:49.231 PMinfoActivation Event: 'CDM-Escalier-D' switch on
app:2202022-10-07 02:49:49.227 PMdebugEvent: CDM-Escalier-D level 10
dev:1142022-10-07 02:49:49.185 PMinfoCDM-Escalier-D was turned on
dev:1142022-10-07 02:49:49.183 PMinfoCDM-Escalier-D was set to 10
dev:1142022-10-07 02:49:49.180 PMdebugparse:zw device: 41, command: 2603, payload: 00 0A 09 , isMulticast: false
app:2202022-10-07 02:49:48.871 PMdebugEvent: CDM-Escalier-D switch off
app:2202022-10-07 02:49:48.828 PMdebugEvent: RDC-Escalier-D3w switch off
app:2202022-10-07 02:49:48.799 PMdebugEvent: CDM-Escalier-D level 0
app:2202022-10-07 02:49:48.770 PMdebugEvent: 2e-SDB-D level 0
app:2202022-10-07 02:49:48.728 PMdebugEvent: SS-Lavage-D switch off
app:2202022-10-07 02:49:48.684 PMdebugEvent: 2e-SDB-D switch off
app:2202022-10-07 02:49:48.639 PMdebugEvent: RDC-Cuisine-D switch off
app:2202022-10-07 02:49:48.535 PMdebugEvent: RDC-Cuisine-D level 0
app:2202022-10-07 02:49:48.480 PMdebugEvent: Garage- EscalierSS-D switch off
dev:112022-10-07 02:49:48.431 PMinfoRDC-HallEntree-KP was turned off
app:2202022-10-07 02:49:48.424 PMdebugEvent: SS-Lavage-D level 0
app:2202022-10-07 02:49:48.369 PMdebugEvent: Garage- EscalierSS-D level 0
app:2202022-10-07 02:49:48.284 PMdebugEvent: RDC-Cuisine-3w switch off
app:2202022-10-07 02:49:48.233 PMdebugEvent: RDC-EscalierSS-D level 0
app:2202022-10-07 02:49:48.133 PMdebugEvent: SS-Rangement-D switch off
app:2202022-10-07 02:49:48.069 PMdebugEvent: RDC-Cuisine-3w level 0
app:2202022-10-07 02:49:47.962 PMdebugEvent: RDC-SalleManger-D switch off
app:2202022-10-07 02:49:47.894 PMdebugEvent: RDC-SalleManger-D level 0
app:2202022-10-07 02:49:47.840 PMdebugEvent: 2e-SDB-Bain-D switch off
app:2202022-10-07 02:49:47.738 PMdebugEvent: RDC-HallEntree-D3w switch off
app:2202022-10-07 02:49:47.484 PMdebugEvent: RDC-EscalierSS-D switch off
app:2202022-10-07 02:49:47.409 PMdebugEvent: SS-Vin-D switch off
dev:492022-10-07 02:49:47.360 PMinfo2e-SDB-D was turned off
dev:492022-10-07 02:49:47.355 PMinfo2e-SDB-D was set to 0
app:2202022-10-07 02:49:47.321 PMdebugEvent: RDC-HallEntree-D3w level 0
app:2202022-10-07 02:49:47.266 PMdebugEvent: 2e-SDB-Bain-D level 0
app:2202022-10-07 02:49:47.100 PMdebugEvent: RDC-Comptoire-D switch off
app:2202022-10-07 02:49:47.033 PMdebugEvent: RDC-Comptoire-D level 0
app:2202022-10-07 02:49:46.980 PMdebugEvent: SS-Rangement-D level 0
app:2202022-10-07 02:49:46.887 PMdebugEvent: SS-Vin-D level 0
app:2202022-10-07 02:49:46.819 PMdebugEvent: SS-tv-D switch off
app:2202022-10-07 02:49:46.685 PMdebugEvent: RDC-Salon-D switch off
app:2202022-10-07 02:49:46.611 PMdebugEvent: SS-tv-D level 0
dev:502022-10-07 02:49:46.540 PMinfo2e-SDB-Bain-D was turned off
dev:502022-10-07 02:49:46.538 PMinfo2e-SDB-Bain-D was set to 0
app:2202022-10-07 02:49:46.417 PMdebugEvent: RDC-Salon-D level 0
app:2202022-10-07 02:49:46.313 PMdebugEvent: SS-EscalierSS-D3w switch off
app:2202022-10-07 02:49:46.052 PMdebugEvent: SS-EscalierSS-D3w level 0
app:2202022-10-07 02:49:45.966 PMdebugEvent: RDC-Escalier-D3w level 0
app:2202022-10-07 02:49:45.888 PMdebugEvent: RDC-Ilot-D switch off
app:2202022-10-07 02:49:45.812 PMdebugEvent: 2e-2e-D switch off
app:2202022-10-07 02:49:45.712 PMdebugEvent: 2e-2e-D level 0
dev:202022-10-07 02:49:45.708 PMinfoRDC-Comptoire-D was turned off
dev:202022-10-07 02:49:45.706 PMinfoRDC-Comptoire-D was set to 0
app:2202022-10-07 02:49:45.633 PMdebugEvent: RDC-Ilot-D level 0
app:2202022-10-07 02:49:45.397 PMdebugEvent: 2e-BureauVanessa-D switch off
dev:1142022-10-07 02:49:45.307 PMinfoCDM-Escalier-D was turned off
dev:1142022-10-07 02:49:45.305 PMinfoCDM-Escalier-D was set to 0
dev:1142022-10-07 02:49:45.301 PMdebugparse:zw device: 41, command: 2603, payload: 00 00 05 , isMulticast: false
dev:122022-10-07 02:49:45.281 PMinfoRDC-HallEntree-D3w was turned off
dev:502022-10-07 02:49:45.280 PMinfo2e-SDB-Bain-D was turned off
dev:502022-10-07 02:49:45.277 PMinfo2e-SDB-Bain-D was set to 0
dev:202022-10-07 02:49:45.275 PMinfoRDC-Comptoire-D was turned off
dev:122022-10-07 02:49:45.271 PMinfoRDC-HallEntree-D3w was set to 0
dev:202022-10-07 02:49:45.244 PMinfoRDC-Comptoire-D was set to 0
dev:1272022-10-07 02:49:45.236 PMinfoSS-Vin-D was turned off
dev:1272022-10-07 02:49:45.234 PMinfoSS-Vin-D was set to 0
dev:1272022-10-07 02:49:45.228 PMdebugparse:zw device: 4B, command: 2603, payload: 00 00 05 , isMulticast: false
dev:1282022-10-07 02:49:45.228 PMinfoSS-tv-D was turned off
dev:1262022-10-07 02:49:45.226 PMinfoRDC-Salon-D was turned off
dev:1282022-10-07 02:49:45.225 PMinfoSS-tv-D was set to 0
dev:1262022-10-07 02:49:45.222 PMinfoRDC-Salon-D was set to 0
dev:1282022-10-07 02:49:45.222 PMdebugparse:zw device: 4C, command: 2603, payload: 00 00 05 , isMulticast: false
dev:1262022-10-07 02:49:45.219 PMdebugparse:zw device: 4A, command: 2603, payload: 00 00 05 , isMulticast: false
dev:1202022-10-07 02:49:45.204 PMinfoSS-EscalierSS-D3w was turned off
dev:182022-10-07 02:49:45.204 PMinfoRDC-SalleManger-D was turned off
dev:362022-10-07 02:49:45.192 PMinfoSS-Rangement-D was turned off
dev:1202022-10-07 02:49:45.192 PMinfoSS-EscalierSS-D3w was set to 0
dev:182022-10-07 02:49:45.189 PMinfoRDC-SalleManger-D was set to 0
dev:1202022-10-07 02:49:45.188 PMdebugparse:zw device: 47, command: 2603, payload: 00 00 05 , isMulticast: false
dev:362022-10-07 02:49:45.168 PMinfoSS-Rangement-D was set to 0
dev:492022-10-07 02:49:45.162 PMinfo2e-SDB-D was turned off
dev:492022-10-07 02:49:45.157 PMinfo2e-SDB-D was set to 0
dev:352022-10-07 02:49:45.128 PMinfoSS-Lavage-D was turned off
dev:1172022-10-07 02:49:45.128 PMinfoRDC-Cuisine-D was turned off
dev:352022-10-07 02:49:45.113 PMinfoSS-Lavage-D was set to 0
dev:1172022-10-07 02:49:45.107 PMinfoRDC-Cuisine-D was set to 0
dev:1172022-10-07 02:49:45.104 PMdebugparse:zw device: 44, command: 2603, payload: 00 00 05 , isMulticast: false
dev:1192022-10-07 02:49:45.094 PMinfoGarage- EscalierSS-D was turned off
dev:1192022-10-07 02:49:45.065 PMinfoGarage- EscalierSS-D was set to 0
dev:1192022-10-07 02:49:45.061 PMdebugparse:zw device: 46, command: 2603, payload: 00 00 05 , isMulticast: false
app:2202022-10-07 02:49:45.059 PMdebugEvent: 2e-BureauVanessa-D level 0
dev:1182022-10-07 02:49:44.744 PMinfoRDC-EscalierSS-D was turned off
dev:1182022-10-07 02:49:44.741 PMinfoRDC-EscalierSS-D was set to 0
dev:1162022-10-07 02:49:44.728 PMinfoRDC-Cuisine-3w was turned off
dev:1182022-10-07 02:49:44.710 PMdebugparse:zw device: 45, command: 2603, payload: 00 00 05 , isMulticast: false
dev:1162022-10-07 02:49:44.725 PMinfoRDC-Cuisine-3w was set to 0
dev:1162022-10-07 02:49:44.722 PMdebugparse:zw device: 43, command: 2603, payload: 00 00 05 , isMulticast: false
dev:1142022-10-07 02:49:44.705 PMinfoCDM-Escalier-D was turned off
dev:1142022-10-07 02:49:44.703 PMinfoCDM-Escalier-D was set to 0
dev:1142022-10-07 02:49:44.698 PMdebugparse:zw device: 41, command: 2603, payload: 00 00 05 , isMulticast: false
dev:1152022-10-07 02:49:44.685 PMinfoRDC-Escalier-D3w was turned off
dev:1152022-10-07 02:49:44.647 PMinfoRDC-Escalier-D3w was set to 0
dev:1152022-10-07 02:49:44.638 PMdebugparse:zw device: 42, command: 2603, payload: 00 00 05 , isMulticast: false
app:2202022-10-07 02:49:44.624 PMdebugEvent: 2e-BureauJP-D switch off
dev:1322022-10-07 02:49:44.598 PMinfoRDC-Ilot-D was turned off
dev:1132022-10-07 02:49:44.597 PMinfo2e-2e-D was turned off
dev:1132022-10-07 02:49:44.594 PMinfo2e-2e-D was set to 0
dev:1322022-10-07 02:49:44.592 PMinfoRDC-Ilot-D was set to 0
dev:1132022-10-07 02:49:44.578 PMdebugparse:zw device: 40, command: 2603, payload: 00 00 05 , isMulticast: false
dev:1322022-10-07 02:49:44.565 PMdebugparse:zw device: 4F, command: 2603, payload: 00 00 05 , isMulticast: false
dev:1312022-10-07 02:49:44.546 PMinfo2e-BureauVanessa-D was turned off
app:2202022-10-07 02:49:44.534 PMdebugEvent: 2e-BureauJP-D level 0
dev:1312022-10-07 02:49:44.523 PMinfo2e-BureauVanessa-D was set to 0
dev:1312022-10-07 02:49:44.520 PMdebugparse:zw device: 4E, command: 2603, payload: 00 00 05 , isMulticast: false
dev:1302022-10-07 02:49:44.479 PMinfo2e-BureauJP-D was turned off
dev:1302022-10-07 02:49:44.477 PMinfo2e-BureauJP-D was set to 0
dev:1302022-10-07 02:49:44.473 PMdebugparse:zw device: 4D, command: 2603, payload: 00 00 05 , isMulticast: false
app:2202022-10-07 02:49:44.467 PMdebugEvent: RDC-HallEntree-KP switch off
dev:112022-10-07 02:49:44.414 PMinfoRDC-HallEntree-KP was turned off
dev:102022-10-07 02:49:44.231 PMinfoRDC-Facade-D was turned off
dev:102022-10-07 02:49:44.229 PMinfoRDC-Facade-D was set to 0
app:2202022-10-07 02:49:43.814 PMinfooff: RDC-Comptoire-D
app:2202022-10-07 02:49:43.796 PMinfooff: SS-tv-D
dev:1282022-10-07 02:49:43.786 PMdebugoff()
app:2202022-10-07 02:49:43.777 PMinfooff: SS-Vin-D
dev:1272022-10-07 02:49:43.767 PMdebugoff()
app:2202022-10-07 02:49:43.760 PMinfooff: RDC-Salon-D
dev:1262022-10-07 02:49:43.750 PMdebugoff()
app:2202022-10-07 02:49:43.739 PMinfooff: SS-EscalierSS-D3w
dev:1202022-10-07 02:49:43.730 PMdebugoff()
app:2202022-10-07 02:49:43.722 PMinfooff: RDC-SalleManger-D
app:2202022-10-07 02:49:43.706 PMinfooff: SS-Rangement-D
app:2202022-10-07 02:49:43.690 PMinfooff: SS-Lavage-D
app:2202022-10-07 02:49:43.674 PMinfooff: RDC-HallEntree-D3w
app:2202022-10-07 02:49:43.657 PMinfooff: RDC-HallEntree-KP
app:2202022-10-07 02:49:43.641 PMinfooff: RDC-Facade-D
app:2202022-10-07 02:49:43.622 PMinfooff: 2e-SDB-Bain-D
app:2202022-10-07 02:49:43.606 PMinfooff: Garage- EscalierSS-D
dev:1192022-10-07 02:49:43.598 PMdebugoff()
app:2202022-10-07 02:49:43.591 PMinfooff: RDC-EscalierSS-D
dev:1182022-10-07 02:49:43.582 PMdebugoff()
app:2202022-10-07 02:49:43.575 PMinfooff: RDC-Cuisine-D
dev:1172022-10-07 02:49:43.565 PMdebugoff()
app:2202022-10-07 02:49:43.558 PMinfooff: RDC-Cuisine-3w
dev:1162022-10-07 02:49:43.549 PMdebugoff()
app:2202022-10-07 02:49:43.541 PMinfooff: RDC-Escalier-D3w
dev:1152022-10-07 02:49:43.533 PMdebugoff()
app:2202022-10-07 02:49:43.525 PMinfooff: CDM-Escalier-D
dev:1142022-10-07 02:49:43.516 PMdebugoff()
app:2202022-10-07 02:49:43.509 PMinfooff: 2e-2e-D
dev:1132022-10-07 02:49:43.499 PMdebugoff()
app:2202022-10-07 02:49:43.492 PMinfooff: RDC-Ilot-D
dev:1322022-10-07 02:49:43.483 PMdebugoff()
app:2202022-10-07 02:49:43.476 PMinfooff: 2e-BureauVanessa-D
dev:1312022-10-07 02:49:43.467 PMdebugoff()
app:2202022-10-07 02:49:43.460 PMinfooff: 2e-BureauJP-D
dev:1302022-10-07 02:49:43.451 PMdebugoff()
app:2202022-10-07 02:49:43.444 PMinfooff: 2e-SDB-D
app:2202022-10-07 02:49:42.764 PMinfoActivating for All Modes
app:2202022-10-07 02:49:42.758 PMinfoActivation Event: time
app:2202022-10-07 02:49:42.757 PMinfoActivation Event: 'Activation Device' Dodo on
dev:1232022-10-07 02:49:42.737 PMinfoDodo was turned on
